Xiaomi Temperature Sensor Conversion
  • Xiaomi Temperature Sensor Conversion
    Very easy pairing the Xiaomi Temperature Sensor. Trying to use the conversion expression from mcsMQTT manual. No matter what I try it displays zero.
    "4.1.15 How do I change Payload temperature from Centigrade to Fahrenheit
    A transformation can be performed on a payload before it is stored into a HS Device. For textual transformation regular expressions can be used most easily. For numeric transformation then numeric expressions can be used. In this case it will be a numeric expression “$$PAYLOAD * 1.8 + 32” that is entered on the Expression row of the Edit tab."
    I have tried “$$PAYLOAD * 1.8 + 32” and $$PAYLOAD * 1.8 + 32 I tried just $$PAYLOAD to see if it would display the original Centigrade value, still zero.
    I am entering this on the edit tab in the field labeled "Expression"
    What am i doing wrong?
    Jim
    Nevermind, got it working. Found this post https://forums.homeseer.com/forum/li...-to-fahrenheit
    Should use search first.....
      Should have fixed the manual the first time to include the colon at the end. Sorry about that.
        No problem, everything worked out in the end.
