Xiaomi Temperature Sensor Conversion
  • AutomatedJim
    No problem, everything worked out in the end.
  • Michael McSharry
    Should have fixed the manual the first time to include the colon at the end. Sorry about that.
  • AutomatedJim
    Nevermind, got it working. Found this post https://forums.homeseer.com/forum/li...-to-fahrenheit
    Should use search first.....
  • AutomatedJim
    started a topic Xiaomi Temperature Sensor Conversion
    Very easy pairing the Xiaomi Temperature Sensor. Trying to use the conversion expression from mcsMQTT manual. No matter what I try it displays zero.
    "4.1.15 How do I change Payload temperature from Centigrade to Fahrenheit
    A transformation can be performed on a payload before it is stored into a HS Device. For textual transformation regular expressions can be used most easily. For numeric transformation then numeric expressions can be used. In this case it will be a numeric expression “$$PAYLOAD * 1.8 + 32” that is entered on the Expression row of the Edit tab."
    I have tried “$$PAYLOAD * 1.8 + 32” and $$PAYLOAD * 1.8 + 32 I tried just $$PAYLOAD to see if it would display the original Centigrade value, still zero.
    I am entering this on the edit tab in the field labeled "Expression"
    What am i doing wrong?
    Jim
