I'm brand new to MQTT and the mcsMQTT plugin. I successfully installed an MQTT broker and the mcsMQTT plugin and have it basically working. However, I've hit a road block that is driving me insane. I feel like a bumbling idiot. I created a device by entering a Topic using the Add/Edit tab. I want to add some Status Graphics to the device, but it says "Device settings prevent editing/adding value/graphics pairs". So I went back to the plugin Add/Edit tab and unchecked NO_GRAPHICS_DISPLAY. But there is no way to save the change. How do you make the change stick?
I also tried to change the Subscribe Topic. Same issue. However, if I change the Topic in the top field (gray), a new HS Device is created. I then went back to Edit the original device by entering its reference number an I get an error that says it doesn't exist (when it clearly does still exist).
So what in the world am I missing?
Any help would be greatly appreciated.
Mike
Mike
