Update to mcsMQTT V3.4.20.3 shows error
  • Update to mcsMQTT V3.4.20.3 shows error
    Feb-09 5:28:20 PM Updater Copying file: /HomeSeer/html/mcsMQTT/FF8877_DKBLUE_14.png
    Feb-09 5:28:20 PM Updater Copying file: /HomeSeer/html/mcsMQTT/FF8AA7_FADE_8.png
    Feb-09 5:28:20 PM Updater Error, package file not found: /HomeSeer/Updates3/mcsMQTT3.4.20.3/FF8AA7_FADE_8.png
    Feb-09 5:28:20 PM Updater Error Installation of package mcsMQTT failed. Try disabling the plugin first, then re-try the update.
    Feb-09 5:28:20 PM Updater Install/Update of package mcsMQTT failed.
    Looks like it is only png and it appears to be running fine.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e 64 bit Intel CPU - Mono 6.00
    Homeseer Zee2 (Lite) - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e BeeLink 4Gb BT3 Pro - Mono 6.00
    These are the IR codes and colors on the 24 button Remote that came with the dirt-cheap magichome controllers. I have HS setup to show the color that corresponds to the color of the button that was pressed. The IR code is used in Tasmota rules to turn a LED green or blue on my notification frame to acknowledge that the notification has been serviced.
      Will do and thank you Michael.
      Updated.
      Did you write a mcsTasmota bin for the Magic home controller?
      I am still using the Espurna modded bin here with the digital pot. Never did configure one for use with the remote control. Just built two of these for use with the Kitchen counters. For one LED set joined three LED strips.
      Another endeavor here is making a new LED strip mounted on an aluminum track with diffuser. This one though will utilize warm white and be over the cabinets and the run is some 8 feet or so long. Rather than using the current switch box going to the metal box over the microwave next to the vent using the same tiny LED power suppy driver. This one will be totally automated for indirect lighting on top of the cabinet. The diffuser does a more even light than just tacking the strip to the top of the cabinet.
      For the office here strips just tacked the strip to the top of the book shelves. These strips though are controlled by a 120 to 12VDC dimmable power supply and use a UPB switch.
      - Pete
      Auto mator
