Just installed a fresh system and I'm getting this during install and after trying to start the plugin.
System info:
Windows 10 Pro
HS3 .500
Plugins: Z-Wave
System info:
Windows 10 Pro
HS3 .500
Plugins: Z-Wave
HTML Code:
Feb-10 21:53:07 Plug-In Finished initializing plug-in mcsMQTT Feb-10 21:53:07 Starting Plug-In mcsMQTT loaded in 433 milliseconds Feb-10 21:53:07 Info Plugin mcsMQTT with instance: has disconnected Feb-10 21:53:07 Error Initializing plug-in(1): mcsMQTT Instance::InitHW Could not load file or assembly 'Mono.Data.Sqlite, Version=2.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756' or one of its dependencies. The system cannot find the file specified. Time to load: 51 milliseconds Feb-10 21:53:07 mcsMQTT InitHW Line 0 Could not load file or assembly 'Mono.Data.Sqlite, Version=2.0.0.0, Culture=neutral, PublicKeyToken=0738eb9f132ed756' or one of its dependencies. The system cannot find the file specified. Feb-10 21:53:07 mcsMQTT Version 3.4.20.3 Registered with Homeseer Feb-10 21:53:07 Starting Plug-In Initializing plugin mcsMQTT ... Feb-10 21:53:07 Info Plugin mcsMQTT has connected. IP:127.0.0.1:51811 Feb-10 21:52:14 Updater Install/Update of package mcsMQTT failed. Feb-10 21:52:14 Updater Error Installation of package mcsMQTT failed. Try disabling the plugin first, then re-try the update. Feb-10 21:52:14 Updater Error, package file not found: C:\Program Files (x86)\HomeSeer HS3\Updates3\mcsMQTT3.4.20.3\FF8AA7_FADE_8.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF8AA7_FADE_8.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF8877_DKBLUE_14.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF7887_TEAL_6.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF708F_LTPURPLE_7.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF6897_BLUE_10.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF50AF_PEACH_5.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF48B7_LTGREEN_11.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF38C7_YELLOW_21.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF32CD_LTBLUE_2.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF30CF_SMOOTH_24.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF28D7_DKTEAL_22.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF20DF_PURPLE_3.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\FF02FD_Orange_1.png Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\mcsMQTT\mcsMQTT.pdf Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_MCSMQTT.exe.config Feb-10 21:52:14 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_MCSMQTT.exe Feb-10 21:52:13 Updater Installing package mcsMQTT Feb-10 21:52:13 Updater Update hspi_mcsmqtt.exe downloaded successfully Feb-10 21:52:09 Updater Downloading update: mcsMQTT Feb-10 21:52:09 Updater Starting download of updates
