mcsMQTT 3.5.5.0 for Windows 32 bit.
  • mcsMQTT 3.5.5.0 for Windows 32 bit.
    Just noticed that I am getting an error trying to run the plugin in Windows 2003 32 bit server. I am running the plugin fine in HS3 Pro for Ubuntu.
    This is what I see in the logs. The plugin does not start.
    Click image for larger version  Name:	mcs.jpg Views:	1 Size:	48.5 KB ID:	1290508
    - Pete
    Auto mator
    HS4 Pro - V4.0.9.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
    HS4 Lite -
    This is compiled with .NET 4.5.2 as the target framework. Do you have this framework on your server? I can run the plugin on W7 32 bit without issue.
      Thank you Michael.
      Yeah Windows 2003 32 bit server only goes to dot net 4.0.
      Will upgrade the VB to W7 32 bit
      Created a 10Gb W7 Starter VB for this endeavor.
      Mostly doing SAPI (6 instances of speaker dot exe) and back porting ethernet serial ports (from Quatech serial server) to Ubuntu main OS.
      Geez Windows 7 starter max RAM is 2Gb.
      - Pete
      Auto mator
      HS4 Lite -
