How To:TRÅDFRI/TRADFRI 5 button remote setup
  • How To:TRÅDFRI/TRADFRI 5 button remote setup
    Hi, this one gave me some grief so i figured i would share how i made it work.
    i am referring to this remote:
    https://www.ikea.com/us/en/catalog/products/20303317/
    first off. this needs NEWER firmware than the Nov 2018 on the zigbee stick so keep that in mind.
    This remote DOES NOT need paring. you put a battery in it and it shows up as:
    zigbee2mqtt/deviceID:action
    it has the following values:
    toggle
    brightness_down_click
    brightness_up_click
    arrow_right_click
    arrow_left_click
    brightness_up_hold
    brightness_down_hold
    brightness_down_release
    arrow_right_hold
    arrow_right_release
    arrow_left_hold
    arrow_left_release
    brightness_up_release
    so this gives us 13 actions to trigger events from!
    there is also a linkquality and duration sub but for some reason no battery.
    To trigger i used a "device had its value set to" on the action and picked the action i wanted.
    Toggle on off was a bit tricky due to a lack of else in the homeseer engine so it triggers 2 events, one that checks if the device is on and the other to see if it is off then it inverts it.
    Edit:
    if you have spuds easy trigger plugin, you can use that for toggle on off and dim up and down.
    hope this helps someone
    Raptor
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
    This is a good approach using VSP to hold the various button push values.
    ​Another option for those comfortable with scripting is to trigger on the topic or trigger on the device change and then use script if/else or case to execute the specific actions.
    Is mcsMQTT handling two consecutive pushes of the same button to your satisfaction?
    If you hold a up or down button do you get repeated MQTT message in a slewing style or does the remote only have on message per button push?
      Yes it seems to be managing 2 pushes of the same button ok.
      not sure on the button hold down, the device its self reports the long presses
        On RGBGenie for brightness control buttons it reports a "start" on long press and "stop" on release.
