Run on a remote computer from homeseer?
  • Run on a remote computer from homeseer?
    Hi,
    Can this plugin be installed on a separate computer from the computer that HomeSeer runs on?
    I know the MQTT server can be on a separate computer, could I set up the plugin on that computer and
    remotely connect it to Homeseer?
    I know this can be done with the RaspberryIO plugin, and I think Pete did it with the zwave plugin.
    I looked through the forum and the manual.
    Bruce
    This should be able to be done with any HS3 plugin as that is one of the design objectives of HS3. Pass the IP of HS3 in the invocation line of HSPI_mcsMQTT.exe. If no parameter it defaults to localhost.
      ok thanks. I'll give it a shot
      Bruce
        Just tested it from new mini HS3 build (192.168.244.149) to HS3 Pro (192.168.244.171) build (both Ubuntu Linux 18.04)
        Client running:
        root@ICS-TX9:/opt/HomeSeer# mono HSPI_MCSMQTT.exe server=192.168.244.171
        Plugin: mcsMQTT Instance: Connecting to server at 192.168.244.171
        Client Connection Requested
        Callback Established
        Connection Monitoring Starting
        Click image for larger version  Name:	mcsMQTT-Remote.jpg Views:	1 Size:	21.0 KB ID:	1301407
        Works fine Linux to Linux.
        Windows 7 to Ubuntu Linux
        Click image for larger version  Name:	mcsMQTT-Remote from W7.jpg Views:	1 Size:	114.5 KB ID:	1301408
        HS3 Pro on Linux
        Click image for larger version  Name:	mcsMQTT-Remote from W7A.jpg Views:	1 Size:	13.1 KB ID:	1301409 Works fine
        Linux remote to Windows 7
        root@ICS-HS3Pro:/opt/HomeSeer# mono HSPI_MCSMQTT.exe server=192.168.244.170
        Plugin: mcsMQTT Instance: Connecting to server at 192.168.244.170
        Click image for larger version  Name:	LinuxtoWindows7.jpg Views:	1 Size:	20.7 KB ID:	1301411
        Works fine.
        xxx
        - Pete
        Auto mator
        Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
        Homeseer Zee2 (Lite) - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
          Forgive my ignorance, what would be the reason to run the mcsMQTT plugin on a separate remote computer? To save CPU cycles on the main HS3 computer perhaps? If so, I didn't think mcsMQTT took much in terms of CPU cycles - at least on my HS3 Win 10 PC running on a 6th gen i7 Intel with 8 GB RAM.
            Client running:
            HS3 Pro on Linux
            Works fine.
            xxx
            omg thanks Pete. So much fun to come!!
              taylormia in my plugin testing between Linux an Windows I do use the remote capability. I haven multiple api class computers and from an organizational perspective I can see doing cross-platform implementations. in other cases where the physical interface is not the ubiquitous IP then the remote connection may be mandated.
                ok. thanks.
