HS3 ZEE S2 install?
  • HS3 ZEE S2 install?
    Can this all be setup on the HS3 ZEE S2 (broker/plug-in/dongle)? I'm new to HS3 and just getting going with some basic stuff. I'd like to interface with a few zigbee devices from within HS. I tried reading the user guide from the plug-in page but the pdf gives me an error when I try to open/save it.
    My understanding is the S2 is a RPi under Debian. If I am correct it is a similar configuration as I run HS3 and can have the Zigbee dongle and the MQTT broker on the same computer. The manual is also at http://mcsSprinklers.com/mcsMQTT.pdf.
      Thanks for the quick response and for sending that dongle. I'll probably start messing around with it in a week or so.
        Michael, I just wanted to let you know that I finally got my first zigbee Xiaomi Aquara contact sensor and set it up without a problem with all of it running contained on the Zee S2. Thanks for your help/plugin/dongle. Good stuff and cheaper contact sensors.
          Glad you had success.
