Pluginstay in ''runing'' state when has been shut down.
  • Pluginstay in ''runing'' state when has been shut down.
    I am shutthing hs3 down with
    systemctl stop hs3.service
    But mcsmqtt stay up every time. I don't know since when this behavior started.
    I am using the very last version of mcsmqtt , on a x64 Linux ubuntu box. Last stable version of mono too.
    Look in the debug file. When mcsMQTT receives the shutdown request from HS it puts "Shutdown IO" in the log.
    mcsMQTT and all local plugins are started and stopped by HS. There really is not too much processing happening in the shutdown sequence that should confuse HS. What did change when I added Express mode and did general optimization is that the database stores generally did not occur during normal operation, but only occurred during shutdown.
      after restarting hs3 two times then stopping it.. i now have two process with mcsmqtt .
      I will send you the log via pm
        Seems like you have exceded you msg quota. I have sent it to your email address. support a mcsSprinklers dot com
          I did not see any shutdownio in the log. This means to me that you are not using a normal shutdown process for HS and just using Linux to kill its process. This means HS has no opportunities to close down its spawned processes in a normal manner. HS under Linux does provide tools/scripts to do a shutdown via browser. Suggest looking at those to see if there is a way to automate it. Aborting rather than normal shutdown could have implications to the integrity on the next startup.
            Thanks Michael. If you open it with notepadd++ it is on the line 1829.
            Yes i do a proper shudown via a curl
            7/5/2019 8:57:39 PM 28878 | HSEvent VALUE_CHANGE| 1024| C484F24D-011-Q53| 0| 8| 161
            7/5/2019 8:57:46 PM 36403 | HSEvent VALUE_CHANGE| 1024| ZHAPresence-43| 100| 0| 1108
            7/5/2019 8:57:47 PM 36741 | HSEvent STRING_CHANGE| 64| P-2-LastMessage| Hs3Linux is in the shutDown Process to Iphone_matt| 334
            7/5/2019 8:57:47 PM 37022 | HSEvent VALUE_CHANGE| 1024| P-4-Remaining| 7309| 7310| 336
            7/5/2019 8:57:50 PM 40186 | HSEvent VALUE_CHANGE| 1024| C484F24D-011-Q53| 8| 0| 161
            7/5/2019 8:57:50 PM 40246 | HSEvent VALUE_CHANGE| 1024| C484F24D-011-Q53| 0| 8| 161
            7/5/2019 8:57:56 PM 45766 | ActoOnMessageForTrigger Topic HS3/MemUSED,Payload=123292 /usr/bin/mono /HomeSeer/HSConsole.exe --log
            7/5/2019 8:57:58 PM 47752 | Shutdown IO
            7/5/2019 8:57:58 PM 47757 | MessageSourceExists SELECT count(Source) as extant FROM MQTT_MESSAGE WHERE (Source='Alexa/LastVoiceCommand/salon')=1
            7/5/2019 8:57:58 PM 47759 | UpdateRecord UPDATE MQTT_MESSAGE SET Source='Alexa/LastVoiceCommand/salon',Topic='',Payload='what^1s the alarm',Template='',Pattern='',Replace='',Match='0',LastDate= '2019-07-05 20:43:33',Reject=0,Express=0,Accept=1,RetainFlag=0,PluginDev ice=1,Subscribe=0,Chart=0,History=0,Ref=787,ChangeType=1,Mis c=262416,QOS=0,StatusType=3 WHERE (Source='Alexa/LastVoiceCommand/salon'), result=1, Key=Source
            7/5/2019 8:57:58 PM 47760 | MessageSourceExists SELECT count(Source) as extant FROM MQTT_MESSAGE WHERE (Source='Alexa/LastVoiceCommand/Basement')=1
            7/5/2019 8:57:58 PM 47760 | UpdateRecord UPDATE MQTT_MESSAGE SET Source='Alexa/LastVoiceCommand/Basement',Topic='',Payload='what^1s the alarm',Template='',Pattern='',Replace='',Match='0',LastDate= '2019-07-05 20:43:33',Reject=0,Express=0,Accept=1,RetainFlag=0,PluginDev ice=1,Subscribe=0,Chart=0,History=0,Ref=784,ChangeType=1,Mis c=262416,QOS=0,StatusType=3 WHERE (Source='Alexa/LastVoiceCommand/Basement'), result=1, Key=Source
            7/5/2019 8:57:58 PM 47760 | MessageSourceExists SELECT count(Source) as extant FROM MQTT_MESSAGE WHERE (Source='AlexaLastVoiceCommand/LivinRoom/Hour')=1
            7/5/2019 8:57:58 PM 47760 | UpdateRecord UPDATE MQTT_MESSAGE SET Source='AlexaLastVoiceCommand/LivinRoom/Hour',Topic='',Payload='0',Template='',Pattern='',Replace='' ,Match='0',LastDate='2019-07-05 20:43:33',Reject=0,Express=1,Accept=1,RetainFlag=0,PluginDev ice=1,Subscribe=0,Chart=0,History=0,Ref=795,ChangeType=1,Mis c=262416,QOS=0,StatusType=2 WHERE (Source='AlexaLastVoiceCommand/LivinRoom/Hour'), result=1, Key=Source
            7/5/2019 8:57:58 PM 47761 | MessageSourceExists SELECT count(Source) as extant FROM MQTT_MESSAGE WHERE (Source='AlexaLastVoiceCommand/LivinRoom/Minute')=1
            7/5/2019 8:57:58 PM 47761 | UpdateRecord UPDATE MQTT_MESSAGE SET Source='AlexaLastVoiceCommand/LivinRoom/Minute',Topic='',Payload='0',Template='',Pattern='',Replace= '',Match='0',LastDate='2019-07-05 20:43:33',Reject=0,Express=1,Accept=1,RetainFlag=0,PluginDev ice=1,Subscribe=0,Chart=0,History=0,Ref=794,ChangeType=1,Mis c=262416,QOS=0,StatusType=2 WHERE (Source='AlexaLastVoiceCommand/LivinRoom/Minute'), result=1, Key=Source
            7/5/2019 8:57:58 PM 47761 | MessageSourceExists SELECT count(Source) as extant FROM MQTT_MESSAGE WHERE (Source='AlexaLastVoiceCommand/LivinRoom/Second')=1
            7/5/2019 8:57:58 PM 47762 | UpdateRecord UPDATE MQTT_MESSAGE SET Source='AlexaLastVoiceCommand/LivinRoom/Second',Topic='',Payload='0',Template='',Pattern='',Replace= '',Match='0',LastDate='2019-07-05 20:43:33',Reject=0,Express=1,Accept=1,RetainFlag=0,PluginDev ice=1,Subscribe=0,Chart=0,History=0,Ref=792,ChangeType=1,Mis c=262416,QOS=0,StatusType=2 WHERE (Source='AlexaLastVoiceCommand/LivinRoom/Second'), result=1, Key=Source
            7/5/2019 8:57:58 PM 47762 | MessageSourceExists SELECT count(Source) as extant FROM MQTT_MESSAGE WHERE (Source='Alexa/LastVoiceCommand/Bedroom')=1
              This is my systmed file :
              [Unit]
              Description=HomeSeer HS3 Home Automation Server
              After=network.target
              [Service]
              WorkingDirectory=/HomeSeer
              ExecStart=/usr/bin/mono /HomeSeer/HSConsole.exe --log
              ExecStop=/HomeSeer/stop_homeseer.sh
              Restart=always
              RestartSec=30
              SyslogIdentifier=HomeSeer HS3
              StandardOutput=null
              KillMode=none
              TimeoutStopSec=300
              [Install]
              WantedBy=multi-user.target
              stop_homeseer.sh file
              #!/bin/bash
              cd /opt/HomeSeer
              /usr/bin/curl 'http://127.0.0.1:xxx/JSON?request=runevent&group=Admin&name=Shutdown'
              sleep 60s
              * maybe I should raise this to more than 60 sec? Will try that
              The picture is the event. ( edit: the forum wont allow me to upload tonight?)
              and this is the script the event is calling
              sub Main(parm as object)
                hs.WriteLog("DoShutdown", "Starting shutdown....")
                hs.Shutdown
              End Sub
                Here is an ExecStop script that waits until the mono processes terminate before it exits.
                #!/bin/sh
                # hs3stop.sh - stop the HS3 application
                # supports: systemd service shutdown
                # import login credentials used to login to web server
                # these are ignored if password not required
                inifile=$(dirname $0)/Config/$(basename $0 .sh).ini
                login=
                test -r $inifile && . $inifile
                # extract web server port from settings.ini
                hs3root=$(dirname $0)  # where this script lives
                webport=$(awk -F= '\
                    gsub("\015", "") # remove CR character
                    if ($1 == "gWebSvrPort") print $2
                ' $hs3root/Config/settings.ini)
                # send application shutdown command
                for i in $(seq 1 5)
                do
                    curl -f -s -o /dev/null ${login:+-u} $login -X POST -F 'scriptcmd=hs.shutdow
                n()' -F 'runscript=Execute Command' "http://localhost:$webport/ControlPanel"
                    rc=$?
                    test $rc -eq 0 && break
                    sleep 2
                done
                # if curl cmd unsuccessful, terminate main process
                test $rc -ne 0 -a -n "$MAINPID" && kill $MAINPID
                # delay until all HomeSeer mono processes terminate
                mono=$(which mono) || exit
                while pgrep -af $mono.'*'\(HSConsole\|HomeSeer\)
                do
                    sleep 5
                done
                Included in the download here.
                  yes i just installed it LOL. like at the same time you posted.
                  here is the output of ./hs3stop.sh
                   ./hs3stop.sh
                  { "Response":"ok" }
                  1396 /usr/bin/mono HSConsole.exe --log
                  1946 /usr/bin/mono /HomeSeer/HSPI_ZWave.exe
                  1947 /usr/bin/mono /HomeSeer/HSPI_AKGoogleCalendar.exe
                  1948 /usr/bin/mono /HomeSeer/HSPI_SKWARE_DEVICE_HISTORY.exe
                  1950 /usr/bin/mono /HomeSeer/HSPI_PUSHOVER.exe
                  1952 /usr/bin/mono /HomeSeer/HSPI_Kodi.exe
                  1953 /usr/bin/mono /HomeSeer/HSPI_MeiHarmonyHub.exe
                  1955 /usr/bin/mono /HomeSeer/HSPI_LutronCaseta.exe
                  1966 /usr/bin/mono /HomeSeer/HSPI_JowiHue.exe
                  1969 /usr/bin/mono /HomeSeer/HSPI_Jeedom.exe
                  1981 /usr/bin/mono /HomeSeer/HSPI_SqueezeBox.exe
                  1989 /usr/bin/mono /HomeSeer/HSPI_ULTRALOG3.exe
                  1993 /usr/bin/mono /HomeSeer/HSPI_EasyTrigger.exe
                  1997 /usr/bin/mono /HomeSeer/HSPI_MCSMQTT.exe
                  2680 /usr/bin/mono /HomeSeer/HSPI_MCSMQTT.exe
                    [quote]Thanks Michael. If you open it with notepadd++ it is on the line 1829.[/qutoe]
                    I see it now and also see that you have what looks like around 1200 devices and at the time the debug ended about 50% have been recorded to the database. Looks like you need two to three times the timeout that you originally provisioned with the plugin version you are running.
                    I do see that there is much written to the database during shutdown that does not need to be saved. I can optimize this by saving only those that have changed. It is at http://mcsSprinklers.com/mcsMQTT_4_0_3_1.zip
                      [QUOTE=Michael McSharry;n1314517]
                      Thanks Michael, I will try this version.
                      I now have something like 500 Homeseer devices. I have deleted a bunch o device in the past, so this is why i have high reference number in some... but now the count is 500.
                      Last edited by MattL0; July 7th, 2019, 07:54 PM. Reason: Had entered the wrong number of device.
                        Unfortunately I have the same issue . DO you need any new logs ?
                          The same log as before to see what is happening after Shutdown IO
                            From hs3stop.sh transcript, it's going thru the wait loop around 60 times. Loop time is 5 seconds, so approx. 300 seconds total. So likely the TimeoutStopSec=300 in the service file is what finally terminates it.
                            You could increase that to see if it ever finishes on its own (not sure if that would be of value though).
                              I think it is resolved now ! we'll get to you tomorow. thanks !
                              Edit : this was a false positive ( my systemd was not configured properly , so HomeSeer was not properly shudown. This is why it didnt take time to restart the pc.. )...
                              This is the systemd that i have now that seems to work:
                              [Unit]
                              [Service]
                              ExecStop=/HomeSeer/hs3stop.sh
                              Restart=always
                              RestartSec=30
                              StandardOutput=null
                              KillMode=none
                              TimeoutStopSec=300
                              [Install]
                              This is the output of ''systemctl status hs3'' I just saw
                              ● hs3.service - HomeSeer HS3 Home Automation Server
                                 Loaded: loaded (/etc/systemd/system/hs3.service; enabled; vendor preset: enabled)
                                 Active: active (running) since Sat 2019-07-06 22:39:28 EDT; 7s ago
                               Main PID: 20369 ((System)_06-Jul)
                                  Tasks: 243 (limit: 4915)
                                 Memory: 466.2M
                                 CGroup: /system.slice/hs3.service
                                         ├─ 9122 /bin/sh /HomeSeer/scripts/Hs3Mem.sh
                                         ├─10595 /bin/sh /HomeSeer/scripts/UPSLaudry.sh
                                         ├─14999 /usr/bin/mono /HomeSeer/HSPI_MCSMQTT.exe
                                         ├─18289 /bin/sh /HomeSeer/hs3stop.sh
                                         ├─19646 sleep 30
                                         ├─19691 sleep 30
                                         ├─20369 /usr/bin/mono /HomeSeer/HSConsole.exe --log
                                         ├─20763 sleep 5
                                         ├─20771 /usr/bin/mono /HomeSeer/HSPI_EasyTrigger.exe
                                         ├─20772 /usr/bin/mono /HomeSeer/HSPI_Kodi.exe
                                         ├─20773 /usr/bin/mono /HomeSeer/HSPI_LutronCaseta.exe
                                         ├─20774 /usr/bin/mono /HomeSeer/HSPI_ZWave.exe
                                         ├─20777 /usr/bin/mono /HomeSeer/HSPI_AKGoogleCalendar.exe
                                         ├─20778 /usr/bin/mono /HomeSeer/HSPI_PUSHOVER.exe
                                         ├─20780 /usr/bin/mono /HomeSeer/HSPI_MeiHarmonyHub.exe
                                         ├─20782 /usr/bin/mono /HomeSeer/HSPI_ULTRALOG3.exe
                                         ├─20785 /usr/bin/mono /HomeSeer/HSPI_BLBackup.exe
                                         ├─20788 /usr/bin/mono /HomeSeer/HSPI_SKWARE_DEVICE_HISTORY.exe
                                         ├─20791 /usr/bin/mono /HomeSeer/HSPI_Jeedom.exe
                                         ├─20794 /usr/bin/mono /HomeSeer/HSPI_JowiHue.exe
                                         ├─20797 /usr/bin/mono /HomeSeer/HSPI_SqueezeBox.exe
                                         └─20801 /usr/bin/mono /HomeSeer/HSPI_MCSMQTT.exe
                              Jul 06 22:39:28 automation systemd[1]: This usually indicates unclean termination of a previous run, or service imple
                              Jul 06 22:39:28 automation systemd[1]: hs3.service: Found left-over process 18289 (hs3stop.sh) in control group while
                              Jul 06 22:39:28 automation systemd[1]: hs3.service: Found left-over process 19646 (sleep) in control group while star
                              Jul 06 22:39:28 automation systemd[1]: hs3.service: Found left-over process 19691 (sleep) in control group while star
                              Jul 06 22:39:28 automation systemd[1]: hs3.service: Found left-over process 20366 (sleep) in control group while star
                              Jul 06 22:39:28 automation systemd[1]: Started HomeSeer HS3 Home Automation Server.
                              Mcsmqtt PI do not shutdown when hs is shutdown properly. I send you the log in an instant Michael McSharry. I had to wait the full 300 secs for hs3 to restart when entered the command '' systemctl stop hs3''
