Display the version running
  • Display the version running
    Michael,
    Can we do two things on the next release?
    1. Can you put the program revision somewhere on the General tab. That way we'll know what rev we're running when the "plugins installed" tab does not update during a manual install.
    2. If there is a way to update the "plugin installed" tab whenever the plugin is enabled could you try to add that. I think it only updates when HS3 is restarted unless it's been installed using the standard installation procedure.
    The first one certainly. The second one is with HS.There would be no reason to query plugin since procedure is to use facility to update provided by HS and not a backddoor.
      I figured that would be the case with #2. Thanks for #1.
        Available as 4.1.1.0 at http://mcsSprinklers.com/mcsMQTT_4_1_1_0.zip. Look in General tab, MQTT Management header.
