Status and value = -1 (Unknown)
  • Status and value = -1 (Unknown)
    I'm struggling av bit with a device being set to value -1, even when payload is either 0 or 1.
    What am I doing wrong?
    You are using the same topic for receive and publish which could result in circular logic (i.e. vacuum publishes carpet_mode, HS receives and then publishes carpet_mode, vacuum receives and then responds with status and the cycle repeats). The debug log which is enabled from General tab will have more details to track down things like this. The file is placed in \data\mcsmqtt.
    Otherwise your setup looks to be good and does not provide any insight.
    Another possibility is that something else is writing to device 1839.
      No, there are two different topics?
      Sub: vacuum/status/carpet_mode:enable
      Pub: vacuum/control/carpet_mode
      I'll enable debugging and test some more after the weekend.
        The :enable is part of the payload. The actual topic is the same in both cases. Will wait for your testing.
          But still, vacuum/status vs vacuum/control...
            My mistake, you are correct about the topic.
