I finally got zigbee2mqtt working on Windows, while I failed to get it working on the RPi. In any case, I need some help with my first device. To learn how to use mcsMQTT and zigbee2mqtt, I dusted off an old Securifi peanut on/off switch, which was readily found by the zigbee sniffer. It is not a supported device, so I had to modify the zigbee2mqtt database file as instructed.
mcsMQTT has found the devices associated with the Securifi plug (state, power, current, linkquality) and I have created HS devices. I am using the "state" device to control off and on. It rapidly updates its status, when I manually turn the plug off and on. My problem is that I can not control the device via HS. I modeled the setup after the setup instructions for Sonoff S20, which may be the problem. When I click the control on the device page, the published topic and payload show up on the plugin's Statistics page. However, the last received topic and payload are different and reflect the change I make at the plug itself. I have attached a file with some screen clippings for the device. Appreciate any help. Thanks, in advance. Elliott
