DIY firmware upgrade to ITead S31 Smart Socket switch
    #91
    I run Tasmota on my Sonoff S31's. Google search finds https://tasmota.github.io/docs/devices/Sonoff-S31/ and there are other links.
    mcsMQTT debug has a record of every received message (ActOnMessageForTrigger lines). Looking there will isolate if it is not being sent or if mcsMQTT is not processing it.
      #92
      I had the switch on line at this house and connected to Homeseer and it was working from my recollection.
      Now the switch (and other WiFi switches with Tasmota / Espurna) are in house #2. They are working off of the built in scheduler as I have not put any automation software there.
      I moved 3 Tasmota Gosund switches and 2 Espurna SonOff wall modules there. I just VPN'd to that network and see everything fine.
      I used this for the original MQTT stuff which I utilize for mcsMQTT and Home Assistant.
      For the below I used the HomeAssistant / Configuration show tab.
      switch:
      - platform: mqtt
      state_topic:
      command_topic:
      payload_on: 1
      payload_off: 0
      availability_topic:
      payload_available:
      payload_not_available:
      sensor:
      - platform: mqtt
      state_topic:
      unit_of_measurement: A
      - platform: mqtt
      state_topic:
      unit_of_measurement: V
      - platform: mqtt
      state_topic:
      unit_of_measurement: W
      - platform: mqtt
      state_topic:
      - platform: mqtt
      state_topic:
      - platform: mqtt
      state_topic:
      unit_of_measurement: '%'
      - platform: mqtt
      state_topic:
      unit_of_measurement: kWh
      I still see the old stuff in the mcsMQTT configuration tab even though it is off line here now.
      I do not see an issue with trying to upload the base current Tasmota firmware, then upgrading it and using a Tasmota Template.
      IE: I think these days you can use the firmware updater in Espurna to go to Tasmota or vice versa.
      - Pete
      Auto mator
      Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
      HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
      HS4 Lite -
