I have setup rgb light according to your document (mcsMQTT.pdf) everything is working perfect in homeseer, but Alexa voice and app only allow for color change. When I try and turn off/on or adjust brightness via alexa app or voice I get :
Also in your picture you show your parent device with the last received payload and mine does not.
Please let me know if you see anything in images or logs that I can check.
First few items in logs were executed from HS the last few were executed from alexa app.
Steven G
Jan-31 11:57:23 PM | Error | Problem serializing data for JSON request: Object reference not set to an instance of an object. |
Steven G
