How do I install the new update zip file?
I copied it over to the update/zips directory. It's been a while since I have done this.
homeassistant/light/CFB4C6_LI_5/config {"name":"", "cmd_t":"~cmnd/POWER5", "stat_t":"~tele/STATE", "val_tpl":"{{value_json.POWER5}}", "pl_off":"OFF","pl_on":"ON", "avty_t":"~tele/LWT", "pl_avail":"Online", "pl_not_avail":"Offline", "uniq_id":"CFB4C6_LI_5", "device":{"identifiers":["CFB4C6"],"connections":[["mac","DC:4F:22:CF:B4:C6"]]}, "~":"Wemos/", "bri_cmd_t":"~cmnd/Dimmer", "bri_stat_t":"~tele/STATE", "bri_scl":100, "on_cmd_type":"brightness", "bri_val_tpl":"{{value_json.Dimmer}}"}
Topic: homeassistant/switch/HomeSeer/HSDevice_2792/config Payload: {"name":"NonPluginDevice","stat_t":"Dell-PC/mcsMQTT/Unknown/Unknown/NonPluginDevice","cmd_t":"Dell-PC/mcsMQTT/Unknown/Unknown/NonPluginDevice/command","avty_t":"Dell-PC/mcsMQTT/LWT","pl_avail":"Online","pl_not_avail":"Offline"}
{ "name": "WashingMachinePower", "stat_t": "homeassistant/sensor/HomeSeer/HSDevice_2179/state", "avty_t": "HomeTrollerS/mcsMQTT/LWT", "pl_avail": "Online", "pl_not_avail": "Offline" }
