Michael, I am stuck with this problem, I hope you can help.
The situation is that I have a number of ESP8266 nodeMCU's with different sensors connected to them. These are all communicating with the mcsMQTT plug-in so I can use the readings of the sensors within HS4.
A small display is connected to another ESP8266 and some sensor readings (from the ESP8266 nodes) are displayed on it. This all works perfect.
Now the problem:
I also have some Z-Wave sensors in HS4 and I want some of them displayed as well on the ESP8266 display. The problem is now that I can't figure out how to set up the non-plugin-HS device that works. In the manual I find some hints but with no success. In the figure below you can see what I entered in the different fields.
The RaspberryPi that runs HS4 is 'RPi4-HS3' (sic). The topic reads as Outside/Backyard/Outside temperature (Buiten/achtertuin/Buitentemperatuur).
On the ESP8266 (with the display) I see no callback messages from this device in the Arduino serial monitor.
I am also not sure if it is necessary to make a event in HS4 to publish the topic. If so, I am not sure how to add the value to the topic
In this case I get a callback message: Message arrived [Buiten/achtertuin/Buitentemperatuur] $DV:170:
But not the value of the sensor.
Any help appreciated,
Cor
Now the problem:
Cor
