I did a deep drive into the MQTT world yesterday (about 9 hours) and I managed to get my Conbee II working with the latest zigbee2mqtt on my Debian 9 box AND got mcsMQTT talking to it (from Debian 10 box hosting HS4). Most of my time was spent learning the intricacies of it all (and reading 358 pages of documentation!). I managed to get a Sonoff BASICZBR3 working as well as two AduroSmart Eria CT bulbs...well, mostly. I have On/Off/Dim but no color tuning controls yet. I fought with the 2nd bulb as it would not give me dim controls - I had to manually add that. I found the option to enable HomeAssistant (I think...in zigbee2mqtt?) and that seemed to make the discovery work better but still the 2nd bulb fails to auto create :brightness and neither give me color tuning, yet...
BASICZBR3
1st and 2nd are not exactly the same and I'm not sure how to get CT controls...
1st Eria 81812
2nd Eria 81812
info 2020-06-10 01:44:54: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2020-06-10.01-44-54' filename: log.txt
info 2020-06-10 01:44:54: Starting zigbee2mqtt version 1.13.1 (commit #2cb234c)
info 2020-06-10 01:44:54: Starting zigbee-herdsman...
info 2020-06-10 01:44:54: zigbee-herdsman started
info 2020-06-10 01:44:55: Coordinator firmware version: '{"type":"ConBee2","meta":{"transportrev":0,"product":0,"m aj orrel":38,"minorrel":88,"maintrel":0,"revision":"0x26580700" }}'
info 2020-06-10 01:44:55: Currently 3 devices are joined:
info 2020-06-10 01:44:55: 0x00124b001e728770 (0x00124b001e728770): BASICZBR3 - SONOFF Zigbee smart switch (Router)
info 2020-06-10 01:44:55: 0x00158d00019949bd (0x00158d00019949bd): ZLED-TUNE9 - Trust Smart tunable LED bulb (Router)
info 2020-06-10 01:44:55: 0x00158d0001a6d9d6 (0x00158d0001a6d9d6): ZLED-TUNE9 - Trust Smart tunable LED bulb (Router)
warn 2020-06-10 01:44:55: `permit_join` set to `true` in configuration.yaml.
warn 2020-06-10 01:44:55: Allowing new devices to join.
warn 2020-06-10 01:44:55: Set `permit_join` to `false` once you joined all devices.
info 2020-06-10 01:44:55: Zigbee: allowing new devices to join.
error 2020-06-10 01:44:55: Not connected to MQTT server!
error 2020-06-10 01:44:55: Cannot send message: topic: 'zigbee2mqtt/0x00124b001e728770', payload: '{"state":"OFF","linkquality":131}
info 2020-06-10 01:44:55: Connecting to MQTT server at mqtt://localhost
info 2020-06-10 01:44:55: Connected to MQTT server
info 2020-06-10 01:44:55: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
info 2020-06-10 01:44:55: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":131}'
info 2020-06-10 01:44:55: MQTT publish: topic 'zigbee2mqtt/0x00158d00019949bd', payload '{"state":"ON","brightness":254}'
info 2020-06-10 01:44:55: MQTT publish: topic 'zigbee2mqtt/0x00158d0001a6d9d6', payload '{"state":"ON","brightness":254}'
info 2020-06-10 01:44:55: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.13.1","commit":"2cb234c","coordinator":{"ty pe ":"ConBee2","meta":{"transportrev":0,"product":0,"majorr el": 38,"minorrel":88,"maintrel":0,"revision":"0x26580700"}},"lo g _level":"info","permit_join":true}'
info 2020-06-10 01:44:55: MQTT publish: topic 'homeassistant/switch/0x00124b001e728770/switch/config', payload '{"payload_off":"OFF","payload_on":"ON","value_template":" {{ value_json.state }}","command_topic":"zigbee2mqtt/0x00124b001e728770/set","state_topic":"zigbee2mqtt/0x00124b001e728770","json_attributes_topic":"zigbee2mqtt/0x00124b001e728770","name":"0x00124b001e728770_switch","uniq ue_id":"0x00124b001e728770_switch_zigbee2mqtt","device":{"id entifiers":["zigbee2mqtt_0x00124b001e728770"],"name":"0x00124b001e728770","sw_version":"Zigbee2mqtt 1.13.1","model":"Zigbee smart switch (BASICZBR3)","manufacturer":"SONOFF"},"availability_topic":" zigbee2mqtt/bridge/state"}'
info 2020-06-10 01:44:55: MQTT publish: topic 'homeassistant/sensor/0x00124b001e728770/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_t em plate":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/0x00124b001e728770","json_attributes_topic":"zigbee2mqtt/0x00124b001e728770","name":"0x00124b001e728770_linkquality", "unique_id":"0x00124b001e728770_linkquality_zigbee2mqtt" ,"de vice":{"identifiers":["zigbee2mqtt_0x00124b001e728770"],"name":"0x00124b001e728770","sw_version":"Zigbee2mqtt 1.13.1","model":"Zigbee smart switch (BASICZBR3)","manufacturer":"SONOFF"},"availability_topic":" zigbee2mqtt/bridge/state"}'
info 2020-06-10 01:44:55: MQTT publish: topic 'homeassistant/light/0x00158d00019949bd/light/config', payload '{"brightness":true,"color_temp":true,"schema":"json","com ma nd_topic":"zigbee2mqtt/0x00158d00019949bd/set","brightness_scale":254,"state_topic":"zigbee2mqtt/0x00158d00019949bd","json_attributes_topic":"zigbee2mqtt/0x00158d00019949bd","name":"0x00158d00019949bd_light","uniqu e_id":"0x00158d00019949bd_light_zigbee2mqtt","device":{"iden tifiers":["zigbee2mqtt_0x00158d00019949bd"],"name":"0x00158d00019949bd","sw_version":"Zigbee2mqtt 1.13.1","model":"Smart tunable LED bulb (ZLED-TUNE9)","manufacturer":"Trust"},"availability_topic":"zigbee 2mqtt/bridge/state"}'
info 2020-06-10 01:44:55: MQTT publish: topic 'homeassistant/sensor/0x00158d00019949bd/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_t em plate":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/0x00158d00019949bd","json_attributes_topic":"zigbee2mqtt/0x00158d00019949bd","name":"0x00158d00019949bd_linkquality", "unique_id":"0x00158d00019949bd_linkquality_zigbee2mqtt" ,"de vice":{"identifiers":["zigbee2mqtt_0x00158d00019949bd"],"name":"0x00158d00019949bd","sw_version":"Zigbee2mqtt 1.13.1","model":"Smart tunable LED bulb (ZLED-TUNE9)","manufacturer":"Trust"},"availability_topic":"zigbee 2mqtt/bridge/state"}'
info 2020-06-10 01:44:55: MQTT publish: topic 'homeassistant/light/0x00158d0001a6d9d6/light/config', payload '{"brightness":true,"color_temp":true,"schema":"json","com ma nd_topic":"zigbee2mqtt/0x00158d0001a6d9d6/set","brightness_scale":254,"state_topic":"zigbee2mqtt/0x00158d0001a6d9d6","json_attributes_topic":"zigbee2mqtt/0x00158d0001a6d9d6","name":"0x00158d0001a6d9d6_light","uniqu e_id":"0x00158d0001a6d9d6_light_zigbee2mqtt","device":{"iden tifiers":["zigbee2mqtt_0x00158d0001a6d9d6"],"name":"0x00158d0001a6d9d6","sw_version":"Zigbee2mqtt 1.13.1","model":"Smart tunable LED bulb (ZLED-TUNE9)","manufacturer":"Trust"},"availability_topic":"zigbee 2mqtt/bridge/state"}'
info 2020-06-10 01:44:55: MQTT publish: topic 'homeassistant/sensor/0x00158d0001a6d9d6/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_t em plate":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/0x00158d0001a6d9d6","json_attributes_topic":"zigbee2mqtt/0x00158d0001a6d9d6","name":"0x00158d0001a6d9d6_linkquality", "unique_id":"0x00158d0001a6d9d6_linkquality_zigbee2mqtt" ,"de vice":{"identifiers":["zigbee2mqtt_0x00158d0001a6d9d6"],"name":"0x00158d0001a6d9d6","sw_version":"Zigbee2mqtt 1.13.1","model":"Smart tunable LED bulb (ZLED-TUNE9)","manufacturer":"Trust"},"availability_topic":"zigbee 2mqtt/bridge/state"}'
info 2020-06-10 01:46:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":131}'
info 2020-06-10 01:51:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":131}'
info 2020-06-10 01:56:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":131}'
info 2020-06-10 02:01:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":131}'
info 2020-06-10 02:02:16: MQTT publish: topic 'zigbee2mqtt/0x00158d00019949bd', payload '{"state":"OFF","brightness":254}'
info 2020-06-10 02:02:19: MQTT publish: topic 'zigbee2mqtt/0x00158d0001a6d9d6', payload '{"state":"OFF","brightness":254}'
info 2020-06-10 02:02:22: MQTT publish: topic 'zigbee2mqtt/0x00158d00019949bd', payload '{"state":"ON","brightness":254}'
info 2020-06-10 02:02:24: MQTT publish: topic 'zigbee2mqtt/0x00158d0001a6d9d6', payload '{"state":"ON","brightness":254}'
info 2020-06-10 02:06:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":132}'
info 2020-06-10 02:11:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":132}'
info 2020-06-10 02:16:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":132}'
info 2020-06-10 02:21:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":0}'
info 2020-06-10 02:26:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":132}'
info 2020-06-10 02:31:40: MQTT publish: topic 'zigbee2mqtt/0x00124b001e728770', payload '{"state":"OFF","linkquality":132}'
root@debian:/opt/zigbee2mqtt/data/log/2020-06-10.01-44-54#
BASICZBR3
1st Eria 81812
2nd Eria 81812
