Originally posted by Michael McSharry
View Post
New to MQTT...
HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
Plugins: Z-Wave (via Nortek USB stick
Home Assistant 2021.10.6 running on HA "Blue" ODROID-N2
Add-ons: Android Debug Bridge, Duck DNS, ESPHome, File Editor, Glances, HA Google Drive Backup, InfluxDB, Log Viewer, MariaDB, Mosquitto broker, NGINX SSL Proxy, Node-RED, Portainer, SSH & Web Terminal, Samba, TasmoAdmin, UniFi Controller, Visual Studio Code, WireGuard, Zigbee2mqtt, Z-Wave JS to MQTT
Integrations: AccuWeather, Alexa Media Player, Glances, Google Nest, HACS, HomeSeer, Insteon, IPP, Life360, Local IP, Logitech Harmony Hub, Mobile App, MQTT, My Garage, OpenWeather, Spotify, Tuya Local. Ubiquiti UniFi, Z-Wave JS
Insteon: 2413S Dual Band PLM
Zigbee: zzh! CC2652R Rev A
Z-Wave: RaZberry daughtercard on RPi 1B via ser2net
Originally posted by Michael McSharry View PostI do not know how to do a firmware update. I suspect it is from the company's App.
It failed to succeed though...HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
After my mod to devices.js I figured out how to remove the device from the network. I then obsoleted the topics and rejoined one bulb. It recognized my device entry in devices.js but publiched the same boring topic as before. Also mcsMQTT has not seen the topic yet...
It looked to me as if the update was happening with progress at 4% and 1356 minutes remaining. That is a long download.
Have you tried publishing something like the following to induce the bulb to respond with its status?
Code:zigbee2mqtt/0x00158d00019949bd/set={"state":"ON"","brightness":128,"color_temp":100%}
Originally posted by Michael McSharry View PostIt looked to me as if the update was happening with progress at 4% and 1356 minutes remaining. That is a long download.
So after a few hours today, I got mqtt redeployed on my Pi where my z-wave is and I managed to get one of the Adurosmart 81812 bulbs working properly (the Sonoff was easy). It's not quite the way I want it yet. I discovered that sending 1-512 to the bulb adjusts the temperature from 6000K to 2700K...kinda backwards. Also, I was unable to publish {"color_temp":"xx%"} to take advantage of the new herdsman % formatting.. As soon as I try and surround $$status: or $$value: with quotes I get 'null' in the payload. Also need to figure out how to get the HS slider to show 2700K-6000K (that part is easy) but send the payload as 512-1. Need some convoluted reverse algorithm...
In your payload template you can use inline expression. This is double less-than and double greater-than symbols encasing the expression. Something like
Code:{"color_temp":<<512-$$VALUE:>>}
Originally posted by Michael McSharry View PostIn your payload template you can use inline expression. This is double less-than and double greater-than symbols encasing the expression. Something like
To use the herdsman % syntax the payload needs to be formatted {"color_temp":"50%"}. The second parameter needs to have " ". $$VALUE from HS is just {"color_temp":50}.
I figured out a formula last night in Excel to convert my desire to have 2700K-6000K in HS to 512 to 1 in the payload: =ROUND(512-((RC[-1]-2700)*(511/3300)),0)
I'm guessing that would look something like {"color_temp":<<ROUND(512-(($$VALUE:-2700)*(511/3300)),0)>>} ???HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
Originally posted by dbrunt View PostI figured out a formula last night in Excel to convert my desire to have 2700K-6000K in HS to 512 to 1 in the payload: =ROUND(512-((RC[-1]-2700)*(511/3300)),0)
More to report...
I've discovered that my guess at 1 to 500 for color_temp is incorrect (and therefore my original formula).
The bulb appears to be using 'mireds' as per other Zigbee bulbs...
https://www.home-assistant.io/integrations/light.mqtt/
https://community.home-assistant.io/t/color-temperature-min-max-units-and-ui/4726
https://github.com/Koenkk/zigbee2mqtt/issues/2431153 mireds = 6500 K
500 mireds = 2000 K
I noticed that the Eria bulb did not change temperature above/below a certain amount. 2700K to 6000K is only 446 to 192 mireds. I modified my inbound $$payload and publish $$value: to correctly convert to/from mireds/Kelvin. My slider in HS is now 2700K to 6000K and works as I'd expect.
I also discovered brightness is 0 to 254 rather than 0 to 100 (I wondered why the bulb seemed dim at 100%!!) so I modified the brightness to convert to/from 0-100%/0-254 and now I get full brightness.
Code:round(2000-(($$payload:-500)*(4500/347)),0)
Code:{"state":"ON","color_temp":<<round(500-(($$value:-2000)*(347/4500)),0)>>}
Code:$$payload:/2.54
Code:{"brightness":<<2.54*$$VALUE:>>}
As an aside, Alexa cannot control the color_temp since HS does not seem to have implemented https://developer.amazon.com/en-US/d...ontroller.html, and HS only has 'Dim' and 'Color Control' for device Control Use: attributes; 'Dim' has to be 0-100 only and Color Control triggers Alexa to create an RGB type color control for it which does not work. I've logged an HS4 Feature Request but definitely not holding my breath. They do need to do something though to support Color Tunable only bulbs in the new HS4 Zigbee plugin so we'll see....HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
Re-modified my formula since it is simply M = 1,000,000 / T or T = 1,000,000 / M where M=mireds and T=Temperature in kelvins:
Code:1000000/$$payload: {"state":"ON","color_temp":<<1000000/$$value:>>}
You are becoming an expert on this bulb and the technology.
I have Wemo emulation enabled on my Tasmota firmware of my Garage Door Opener. I use Alexa Routines (Alex App) so Alexa will recognize Open and Close rather than needing On and Off. Hue emulation is also available. I don't know if zigbee2mqtt supports the emulations, but just throwing it out there.
Originally posted by Michael McSharry View PostYou are becoming an expert on this bulb and the technology.
The other issue I discovered is with MyHS. My slider in HS is 'dim' 2000K - 6500K but the slider in MyHS appears to start from 0 since 2000K is 1/3 of the way on. So, MyHS is not completely happy with my setup and Alexa has no idea how to 'dim' my 2000-6500K slider and HS Color Control only caused her to add RGB color selections. I may have to create manually triggered events in HS to select maybe 5 different colors and corresponding Alexa routines that she can 'turn on' if I want voice control and/or enable and use the "Alexa, tell HomeSeer to..." skill.HS4 Pro Edition 4.2.5.0 running on Lenovo ThinkCenter & Debian Linux
