Ring Alarm to MQTT
    Ring Alarm to MQTT
    Installed a Ring Alarm configuration (2nd home installation). This is a replacement for XFinity home.
    Current configuration is use with Echo devices (Show and Dot). Installed the Ring base station using POE.
    With this set up I can monitor both the OmniPro 2 house and the Ring Alarm house. I am also using an OmniPro 2 MQTT plugin (plus the HS OmniPro plugin).
    Noticed a Ring to MQTT add on was available here ==> hxxps://github.com/tsightler/ring-mqtt
    Very impressed with it and have it working now in Docker doing these steps: (note this is a copy and paste from a post on Cocoontech).
    1 - get token
    docker run -it --rm --entrypoint node_modules/ring-client-api/ring-auth-cli.js tsightler/ring-mqtt
    2 - here you put in your ring email address and password and validate login via email
    3 - you will get a very long token which you utilize in the following command line:
    4 - docker run --rm -e "MQTTHOST={host name}" -e "MQTTPORT={host port}" -e "MQTTRINGTOPIC={ring topic}" -e "MQTTHASSTOPIC={hass topic}" -e "MQTTUSER={mqtt user}" -e "MQTTPASSWORD={mqtt pw}" -e "RINGTOKEN={ring refreshToken}" -e "ENABLECAMERAS={true-or-false}" -e "RINGLOCATIONIDS={comma-separated location IDs}" tsightler/ring-mqtt
    5 - validated it working with MQTT explorer
    6 - Issue with me is persistance. It'll stay at the prompt where as I cannot kill the ssh terminal windows. So for time bean went to console and running there. Validated it running with the docker ps command and portainer.
    Note: here with so many Docker containers running decided to install Portainer a few weeks ago. Portainer is also running in Docker.
    - Pete
    Auto mator
    HS4 Pro - Ubuntu 22.04 / Lenova Tiny M900 / 32Gb Ram
    Thanks pete! I just type on github the keywords: mqtt docker. It is crazy what you can file in ‘’easy to deploy’’ docker format.
    Thank for the inspiration! I might use the ring one at my mom’s place if it provides nice option for the doorbell
      I have noticed many MQTT to whatever now in GitHub.
      Here removed the XFinity Home installed at mom's house and installed the Ring Alarm stuff there. I have her Alexa devices now talking in French which she likes.
      - Pete
      Auto mator
        Updated Ring alarm to MQTT application per:
        Ring-MQTT: Do more with your Ring Products
        Configured it with Homeseer - mcsMQTT and Home Assistant.
        Working well.
        - Pete
        Auto mator
          Status: 13th of August, 2020
          Configured speech events locally and remotely based on the Ring alarm status:
          1 - In house #2 with the Ring Alarm installed configured Alexa dot / show speech TTS when enabling or disabling alarm.
          2 - In house #1 configured Homeseer speech to zoned audio system here to speak status when Ring alarm becomes active or diabled. Works great.
          Next
          Configuring speech for garage door open or close status to Amazon devices in House #2 and HS speech in house #1.
          - Pete
          Auto mator
