ONVIF to MQTT
    ONVIF to MQTT
    Here recently installed a Hikvision video doorbell. Have RTSP, JPG and ONVIF working fine with it. Some one wrote an ONVIF to MQTT plugin for it to detect the PIR sensor on the device. I use this in conjunction with the hard wired alarm panel zone doorbell sensor. It's been working great now.
    I am running this in Docker per git hub instructions ==> hxxps://github.com/dmitrif/onvif2mqtt
    Noticing lately a few package delivery folks do not ring the doorbell so utilize the PIR sensor to trigger alerts.
    Here are my steps installing it.
    1 - docker pull dfarkov/onvif2mqtt:latest
    2 - cd /opt
    3 - git clone dmitrif/onvif2mqtt
    4 - mkdir /opt/onvif2mqtt/config
    5 - cd /opt/onvif2mqtt
    6 - nano config.dev.yml
    7 - cp config.dev.yml /opt/onvif2mqtt/config/config.yml
    8 -
    docker run -d --name="onvif2mqtt" -v /opt/onvif2mqtt:/config -v /etc/localtime:/etc/localtime:ro --net=host --restart always dfarkov/onvif2mqtt
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
    HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
    HS4 Lite -
