Gosund WiFi dimmer switches on sale on Amazon
    #16
    Yes. Last time I tried the OTA it was hit or miss and that is why I went back to the JTAG methodology.
    It took all of 15 minutes to update via OTA and then the firmware updates.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
    HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
    HS4 Lite -
      #17
      Michael McSharry
      Not related to OP.
      Question: I am still using the combo GDO with an original Sonoff basic module. It works fine. I have an Alexa direct connect issue with it.
      When configured with Hue emulation and can see it with Alexa running on Windows 10 or if I do a scan of devices with the Echo show it opens the garage door.
      I then shut the garage door toggle on the web gui and it stays shut. It's like the hue device discovery with Alexa toggles it on and opens the garage door.
      I know you custom wrote that Tasmota firmware for the GDO. Would it be beneficial to utilize current Tasmota firmware and would it work with the two sensors, temperature sensor and toggle switch?
      Just did a scan of devices and see this on the Alexa app.
      1 - Garage Door 1 Royal Philips Electronics smart device
      2 - Garage Door 1 Hue Light
      - Pete
      Auto mator
      HS4 Lite -
