Disable Event Action Messages
    I have a number of 1-wire temp sensors I'm pushing into the MQTT world using mcsMQTT. I have an event the publishes the values whenever a sensor value changes, which is quite often. I have logging disabled for these events but I'm still getting a message in the log from the plugin every time something is published. I've looked all around but I can't seem to find anywhere where I can disable these log messages.
    Jul-04 9:51:58 AM mcsMQTT Event Action Publishing HS/1-Wire/NorthSide/Temperature with Payload of 70.91
    Am I missing something?
    Ken
    No option now exists to disable the message. Why are you using event action rather than a simple association of the temperature sensor device with a MQTT publish topic on the Association tab?
      I have several tasks that need to run each time a temp sensor changes value so I just tacked the MQTT publish onto that event. I'll look into creating an association instead.
      Ken
