High CPU Load?
    #16
    Installed the hs3 version here: Works perfect, thanks!
    No errors in logs, no errors seen on console.
    but just saw this in hs log:
    7/10/2020 19:48:45
    HomeSeer
    Warning
    File does not exist: /HomeSeer/html/MQTT
      #17
      Both versions but I did my testing with HS3 plugin. Looks like a HS4 plugin install was never done. The HSPI... download has an installer .json file. If you put both it and the zip In HS4 folder and use Plugins Add menu it will install it.
        #18
        ok thanks Michael . On restart the warning ''File does not exist: /HomeSeer/html/MQTT '' is not there .
          #19
          I also had an issue, that it used so much cpu that homeseer didnt work.
          I now installed the 5.4.0.2 version, and it works better, but it has still high cpu
            #20
            The Statistics tab provide insight into the amount of MQTT traffic being processed. The debug has more including the amount of HS callbacks being serviced. It is enabled from the General tab and data produced in \data\mcsMQTT folder. At startup the CPU load will be high as the plugin initializes.
