Why I can't see and use mscMQTT devices in the event?
    I have some dvices from mscMQTT plugin.
    All works well, i can control them with no problem.
    Now I'm creating an event and surprise! In can't see and use any device.
    Example, i have a bed_light (mqtt device), In the event I select:
    Trigger: the device's value is
    Trigger Type: the device change and becomes
    Device: I can see only some virtual devices created.
    where I'm wrong?
    Here some of my devices:
    Only the first one is a virtual device, the other are MQTT devices.
    Want I want is: "if richiesta_totale_impulsi change and become ON, then...."
    But as you can see this device is not present in the event "device"...
Name:	devices in event.png
    I can see only the virtual devices in the event.
    Cris
    Two things I can think of for HS4. One is that everything needs to have both a floor and a room. Earlier versions of HS3 mcsMQTT created devices without a floor. This can be changed by the user on a device by device basis. The second is that HS4 does not allow control of devices. It allows control of only features. Earlier versions of HS3 mcsMQTT allowed devices to have controls. If you remove the association from the mcsMQTT tab between HS device and the topic (uncheck "A" column from mcsMQTT Association tab) and then associate it again to create a new HS device then both a parent device and child feature should be created.
      Yes Michael, I was writing that I'm stupid. Problem solved. My issue was related about the Floor or second location....
      If I select "board2-stat-boad2-stat" then I can see all devices associated.
      Thanks and apologize for my stupid question (I'm new on HS4).
      Regards
      Cris
