Purchased a Gosund SW1 switch a couple of days ago. Priced right on Amazon $16.99 USD.
I will be using this switch for the garage lighting. It will be triggered by two door sensors - IE: garage door and garage to house door.
Last year installed LED bright lighting in the garage for daylight look. This garage has a 12 foot ceiling height which is a bit difficult to work in.
Going to update this switch to Tasmota / Espurna firmware using Tuya-Convert 2.
There are two Tasmota Templates mentioned over here ==>
hxxps://templates.blakadder.com/gosund_SW1.html
This switch would be using base Tasmota Bin with the template mentioned above.
The alternative is to utilize Espurna firmware which is here ====>
hxxps://github.com/xoseperez/espurna/releases/download/1.14.1/espurna-1.14.1-gosund-ws1.bin
Here is a picture of the pre-installation hard ware configuration. I use an old computer power cable cut and connected to the switch.
Updating firmware using terminal window in Ubuntu 18.04 on my Lenova Laptop.
Here is a copy and paste of the firmware upgrade. NOTE: you should see the following if your firmware OTA is working
/home/pete/Downloads/tuya-convert# ./start_flash.sh
tuya-convert v2.4.4
Checking for network interface wlp4s0... Found.
Checking UDP port 53... Occupied by systemd-resolve with PID 876.
Port 53 is needed to resolve DNS queries
Do you wish to terminate systemd-resolve? [y/N] y
Attempting to stop systemd-resolved.service
Checking UDP port 67... Available.
Checking TCP port 80... Available.
Checking TCP port 443... Available.
Checking UDP port 6666... Available.
Checking UDP port 6667... Available.
Checking TCP port 1883... Occupied by mosquitto with PID 961.
Port 1883 is needed to run MQTT
Do you wish to terminate mosquitto? [y/N] y
Attempting to stop mosquitto.service
Checking TCP port 8886... Available.
Starting AP in a screen..
Starting web server in a screen
Starting Mosquitto in a screen
Starting PSK frontend in a screen
Starting Tuya Discovery in a screen
IMPORTANT
1. Connect any other device (a smartphone or something) to the WIFI vtrust-flash
This step is IMPORTANT otherwise the smartconfig may not work!
2. Put your IoT device in autoconfig/smartconfig/pairing mode (LED will blink fast). This is usually done by pressing and holding the primary button of the device
Make sure nothing else is plugged into your IoT device while attempting to flash.
3. Press ENTER to continue
Starting smart config pairing procedure
Waiting for the device to install the intermediate firmware
Put device in EZ config mode (blinking fast)
Sending SSID vtrust-flash
Sending wifiPassword
Sending token 00000000
Sending secret 0101
SmartConfig complete.
Resending SmartConfig Packets
....../start_flash.sh: line 135: 10341 Terminated ./smartconfig/main.py
IoT-device is online with ip 10.42.42.42
Fetching firmware backup
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 1024k 100 1024k 0 0 69003 0 0:00:15 0:00:15 --:--:-- 32498
curl: Saved to filename 'firmware-c4091f.bin'
Getting Info from IoT-device
VTRUST-FLASH 1.5
(c) VTRUST GMBH hxxps://www.vtrust.de/35c3/
READ FLASH: hxxp://10.42.42.42/backup
ChipID: c4091f
MAC: E0:98:06:C4:09:1F
BootVersion: 7
BootMode: normal
FlashMode: 1M DOUT @ 40MHz
FlashChipId: 144051
FlashChipRealSize: 1024K
Active Userspace: user2 0x81000
Ready to flash third party firmware!
For your convenience, the following firmware images are already included in this repository:
Tasmota v8.1.0.2 (wifiman)
ESPurna 1.13.5 (base)
You can also provide your own image by placing it in the /files directory
Please ensure the firmware fits the device and includes the bootloader
MAXIMUM SIZE IS 512KB
Available options:
0) return to stock
1) flash espurna.bin
2) flash tasmota.bin
q) quit; do nothing
Please select 0-2: 1
Are you sure you want to flash espurna.bin? This is the point of no return [y/N] y
Attempting to flash espurna.bin, this may take a few seconds...
Flashed hxxp://10.42.42.1/files/espurna.bin successfully in 9723ms, rebooting...
Look for an ESPURNA-XXXXXX SSID to which you can connect and configure
Default password is "fibonacci"
Be sure to upgrade to your device specific firmware for proper function!
HAVE FUN!
Do you want to flash another device? [y/N] n
Cleaning up...
Closing AP
Exiting...
It'll install a base Espurna firmware. Here next update it to Gosund Espurna firmware.
Updated to Espurna firmware. Here is a screen picture.
tuya-convert v2.4.4
IMPORTANT
Sending secret 0101
VTRUST-FLASH 1.5
ChipID: c4091f
BootVersion: 7
BootMode: normal
FlashChipId: 144051
Available options:
0) return to stock
q) quit; do nothing
HAVE FUN!
Cleaning up...
Closing AP
Exiting...
