Runaway cpu
    Runaway cpu
    When I install mcsMQTT 5.3.0.4 (on HS3) it takes over the system. I have to disable it and restore a previous version. I'm running Ubuntu 18.04, mono 5.20.1.34. This is the second time I tried it, the first time it ran for over an hour before I noticed that things were not working because of the high cpu utilization. It takes a minute or so, but then it cranks right up to this level and stays between 200 and 350 percent cpu utilization. Previous version works just fine.
    The current version is at http://mcsSprinklers.com/mcsMQTT_5_4_0_7.zip. The other thing is that that if you use a broker password then you will want to reenter it. The encryption mechanism changed so newer plugin versions cannot read the password stored by earlier versions.
