mcsMQTT Plugin V 5.5.1.4 issue
    Want to start from scratch here. I shut off the auto variable generate and the HA stuff and deleted all of the auto configured variables. When I disable and then enable the plugin it auto generates the Home Assistant variables. Ended up with over a thousand HS devices from Home Assistant which I do not want in Homeseer.
    To delete everything what files do I remove?
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
    HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
    HS4 Lite -
    The homeassistant/../CONFIG messages are sent with retain flag set. Stop Mosquitto, delete the Mosquitto database, Start Mosquitto.
      Thank you Michael.
      1 - sudo systemctl stop mosquitto.service
      2 - sudo rm /var/lib/mosquitto/mosquitto.db
      3 - sudo systemctl start mosquitto.service
      - Pete
      Auto mator
      HS4 Lite -
