Thank you Michael.
1 - sudo systemctl stop mosquitto.service
2 - sudo rm /var/lib/mosquitto/mosquitto.db
3 - sudo systemctl start mosquitto.service
mcsMQTT Plugin V 5.5.1.4 issue
The homeassistant/../CONFIG messages are sent with retain flag set. Stop Mosquitto, delete the Mosquitto database, Start Mosquitto.
Want to start from scratch here. I shut off the auto variable generate and the HA stuff and deleted all of the auto configured variables. When I disable and then enable the plugin it auto generates the Home Assistant variables. Ended up with over a thousand HS devices from Home Assistant which I do not want in Homeseer.
To delete everything what files do I remove?Tags: None
