HS device not updating when ON/OFF button pressed after Homeseer restart
    When I add a device to Homeseer (from the Association table). Everything works fine. This device is controllable via a publish topic I have added a Topic on device command.and buttons appear on the Homeseer devices page. This device is controllable (with the ON/OFF buttons and through an event) and status is visible and changing. After a Homeseer restart, this device is still controllable (with the ON/OFF buttons or via an event) but the status is not changing. Removing the device and add it again works until I restart Homeseer.
    I use Homeseer HS4 and plugin 5.5.1.4
    If you publish on topic x/y the plugin will ignore any received x/y topics to avoid a circular loop. Your publish topic should be different than your subscribe topic.
