Question to Michael relating to using an AS3935 Franklin Lighting sensor with Tasmota
    A week or so started a new endeavor here which is actually an updated old endeavor of using a:
    AS3935 Franklin Lightning sensor ==> MQTT
    Initially it was just connecting the sensor to an RPI until today found this:
    The article doesn't mention what Tasmota hardware to use.
    Michael McSharry
    What is it I purchase for this endeavor?
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
    HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
    HS4 Lite -
    Hi Pete,
    ​​​​​​you can hook this sensor to a Sonoff basic or Sonoff TH16. You simply need a Tasmota flashed device with 3 free GPIO ports. You flash the Sonoff with the latest Tasmota-sensors binaries and then make the appropriate connections as per the article you are referring to. You add the MQTT parameters to the Sonoff/Tasmota config and the it will publish sensor data over MQTT.
    This is the short version, let me know if you need further assistance, hope this helps.
    Yann
      Thank you Yann.
      Yes looks easy. Currently using old R1 Sonoff basic devices for 1-Wire hubs. I have 3 set up this way and it works great.
      Have it running fine now with the RPi2. Wondering about power supply noise and best way to approach the endeavor on a Sonoff.
      Thinking of maybe installing device in attic here similiar to old 1-wire lightning sensor (which still works).
      - Pete
      Auto mator
      HS4 Lite -
        My pleasure,
        If you look at my other post (#39) on the GDO thread
        https://forums.homeseer.com/forum/li...sensor-project
        you can order a few Sonoff Basic or TH16 and prewire them.
        The TH16 supports higher current and has somewhat better access to GPIO's, including a 2.5mm jack with one prewired GPIO;
        This last option can be interesting for someone who only needs a single GPIO (read: one-wire devices) or doesn't like to solder.
        Just need to purchase one of these:
        https://www.aliexpress.com/item/4001...archweb201603_ or a standard 2.5mm 4pole male cable.
        Then you can shop the "Candy store...." : https://tasmota.github.io/docs/Supported-Peripherals/ =)
        The AS3935 is #9 of a list of 109 supported peripherals.... hours of fun.
        Other than a long run of daisy chained DS18b20 (8) + Si7021 returning temperature across the house and outdoors, I'm currently testing these 3:
        BME280 5V 3.3V Digital Sensor Temperature Humidity Barometric Pressure Sensor
        https://www.aliexpress.com/item/3284...27424c4d7nvKE4
        GY-9960-3.3 APDS-9960 proximity detection and non-contact gesture detection RGB and Gesture APDS9960 GY-9960
        GY-302 BH1750 BH1750FVI light intensity illumination module 3V-5V
        https://www.aliexpress.com/item/3234...27424c4d7nvKE4
        I also wired my existing/legacy AC doorbell (2 tones) to the Sonoff basic + cheap AC relays so that it can trigger events based on which doorbell is pressed (speak "someone at the front/side door", trigger cameras, presence, lights, etc.)
        Endless possibilities... and sleepless nights ...
          Thank you Yann.
          I have been adding a few MQTT devices slow baby fashion here.
          I like to tinker with hardware and don't mind soldering stuff here.
          So are the newer R2-3 Sonoff basics as easy to work on as the R1 Sonoff basic?
          So here the doorbell button is connected to a zone on the OmniPro 2 panel. Using an Elk 930 doorbell board and an Elk 960 debounce board and current it is also connected to a Hikvision Wireless video doorbell.
          I use the zone trigger to talk SAPI via HS. Also do TTS to Alexa devices here. Just added a ONVIF to MQTT app to sense motion from the Video doorbell. I am connecting to the video doorbell via jpg captures, ONVIF and RTSP. Using an app for displaying camera called Monocle which is a reverse proxy for Amazon Show devices.
          - Pete
          Auto mator
          HS4 Lite -
