mcsMQTT V5.5.2.0 update debends
    Just updated plugin to V5.5.2.0 on Homeseer 3. mcsMQTT fails to start with critical error. "CRITCAL:Plugin has disconnected"
    It keeps trying to start but never does. Disabled it for time bean.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
    HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
    HS4 Lite -
    Do you have any debug information in the mcsMQTT or HS logs?
      Just looked and have a debug text file. Deleted it just now and tried to start the plugin.
      This is what it shows:
      9/16/2020 5:32:55 PM 9 | mcsMQTT Version 5.5.2.0 running at /opt/HomeSeer, HS is at /opt/HomeSeer
      9/16/2020 5:32:55 PM 16 | mcsMQTT HS Plugin InitHW ComputerName= ICS-HS3Pro
      9/16/2020 5:32:55 PM 104 | mcsMQTT Debug InitHW Database Ready
      9/16/2020 5:32:56 PM 344 | mcsMQTT Debug Receive Ready
      9/16/2020 5:32:56 PM 344 | mcsMQTT Debug Trigger Ready
      9/16/2020 5:32:56 PM 417 | HW Init Complete
      9/16/2020 5:32:56 PM 419 | Background Init Started
      9/16/2020 5:32:57 PM 1808 | Background Init Received
      9/16/2020 5:32:58 PM 3094 | Background Send
      9/16/2020 5:32:59 PM 3338 | Background Init Filters - Background Complete
      9/16/2020 5:32:59 PM 3339 | Spawning MQTT Threads
      9/16/2020 5:32:59 PM 3345 | Background Init MQTT - Background Complete Sign FilePath
      9/16/2020 5:32:59 PM 3345 | Background Init Folders - Background Complete
      9/16/2020 5:32:59 PM 3350 | Background Complete
      9/16/2020 5:32:59 PM 3350 | Delayed SetIOMulti Complete
      9/16/2020 5:32:59 PM 3350 | Calling MQTTclient for Broker 1
      9/16/2020 5:32:59 PM 3351 | MQTT Thread Client Created for Broker 1
      9/16/2020 5:32:59 PM 3351 | MQTT Thread Client ID=mcsMQTT on ICS-HS3Pro
      9/16/2020 5:32:59 PM 3351 | Calling MQTT Connect
      9/16/2020 5:32:59 PM 3351 | Pre-connect oMQTTClient(0) is Nothing=False
      9/16/2020 5:32:59 PM 3357 | MQTT Thread Broker 1 192.168.244.150 Connect Response=0
      9/16/2020 5:32:59 PM 3357 | MQTT Broker 1 Connection Accepted, Connected=True to broker 192.168.244.150
      9/16/2020 5:32:59 PM 3362 | MQTT Subscription Start for Broker 1
      9/16/2020 5:32:59 PM 3362 | MQTT Subscription Topics being selected for Broker 1
      9/16/2020 5:32:59 PM 3362 | MQTT Subscription Topics selected for Broker 1
      9/16/2020 5:32:59 PM 3363 | MQTTSubscribe List / Option=2 to
      9/16/2020 5:32:59 PM 3363 | homeassistant/nodes
      Looked at the INI file and see:
      [General]
      DebugLog="0"
      Version=5.5.2.0
      ShowHomeseerSourced="1"
      I was just getting ready to set up the new lightning sensor and saw an update and decided to update.
      Can I downgrade to previous version of the plugin?
      - Pete
      Auto mator
      HS4 Lite -
        The mcsMQTT debug log looks fine, but you do have a rather restrictive subscription list. Not an error, but just an observation.
        Anything from the HS log to provide some hints? I have been doing all my testing with HS4, but did not expect any difference under HS3.
          I am also on linux here. I was having a lot of those type of issue with plugins on 5.1.6. Reverted back to 5.1.4, but the issue was still there (so maybe something broke my system with 5.1.6).
          Loaded a backup from 4 days before and all was good . Maybe this is worth a try if you have one.
            I didn’t think about trying this at first, but maybe you can check the systemd log for this .
            Just change HomeSeer for wtv is your hs service name.
            journalctl -u HomeSeer.service -b
              Yes I had just done that to get the new Lightning sensor. I am doing only MQTT with Home Assistant and have many devices.
              I do not want to put all of those devices in to Homeseer. Redid the whole mcsMQTT configuration with the last revision and the GDO debacle.
              Deleted all of the databases in mcsMQTT and all of the devices that used to be there and recreated all of the stuff I wanted to see. This was done last week.
              Here is what the Homeseer 3 log shows.
              HS4 here is only in test mode started from scratch on it with no import from HS3. HS3 and HS4 are running on two Ubuntu servers.
              Personally for me HS4 is from production mode at this time.
              Sep-16 5:35:57 PM mcsMQTT Version 5.5.2.0 Registered with Homeseer
              Sep-16 5:35:57 PM Starting Plug-In Plugin mcsMQTT started successfully in 74 milliseconds
              Sep-16 5:36:00 PM mcsMQTT MQTTClient is Connected to broker 1 at 192.168.244.150
              Sep-16 5:36:00 PM Info Plugin mcsMQTT with instance: has disconnected
              Sep-16 5:36:27 PM Warning I/O interface mcsMQTT is down, executable is not running, restarting ...
              Sep-16 5:36:27 PM Info Plugin mcsMQTT has connected. IP:127.0.0.1:45496
              Sep-16 5:36:42 PM Starting Plug-In mcsMQTT loaded in 15015 milliseconds
              Sep-16 5:36:42 PM Starting Plug-In Initializing plugin mcsMQTT ...
              Sep-16 5:36:42 PM mcsMQTT Version 5.5.2.0 Registered with Homeseer
              Sep-16 5:36:42 PM Starting Plug-In Plugin mcsMQTT started successfully in 74 milliseconds
              Sep-16 5:36:45 PM mcsMQTT MQTTClient is Connected to broker 1 at 192.168.244.150
              Sep-16 5:36:45 PM Info Plugin mcsMQTT with instance: has disconnected
              Sep-16 5:37:12 PM Warning I/O interface mcsMQTT is down, executable is not running, restarting ...
              Sep-16 5:37:12 PM Info Plugin mcsMQTT has connected. IP:127.0.0.1:45502
              Sep-16 5:37:27 PM Starting Plug-In mcsMQTT loaded in 15016 milliseconds
              Sep-16 5:37:27 PM Starting Plug-In Initializing plugin mcsMQTT ...
              Sep-16 5:37:27 PM mcsMQTT Version 5.5.2.0 Registered with Homeseer
              Sep-16 5:37:27 PM Starting Plug-In Plugin mcsMQTT started successfully in 73 milliseconds
              Sep-16 5:37:31 PM mcsMQTT MQTTClient is Connected to broker 1 at 192.168.244.150
              Sep-16 5:37:31 PM Info Plugin mcsMQTT with instance: has disconnected
              Sep-16 5:37:57 PM Warning I/O interface mcsMQTT is down, executable is not running, restarting ...
              Sep-16 5:37:58 PM Info Plugin mcsMQTT has connected. IP:127.0.0.1:45508
              Sep-16 5:38:12 PM Starting Plug-In mcsMQTT loaded in 15016 milliseconds
              Sep-16 5:38:13 PM Starting Plug-In Initializing plugin mcsMQTT ...
              Sep-16 5:38:13 PM mcsMQTT Version 5.5.2.0 Registered with Homeseer
              Sep-16 5:38:13 PM Starting Plug-In Plugin mcsMQTT started successfully in 66 milliseconds
              Sep-16 5:38:16 PM mcsMQTT MQTTClient is Connected to broker 1 at 192.168.244.150
              Sep-16 5:38:16 PM Info Plugin mcsMQTT with instance: has disconnected
              Sep-16 5:38:43 PM Warning I/O interface mcsMQTT is down, executable is not running, restarting ...
              - Pete
              Auto mator
              HS4 Lite -
                Pete . I had the exam same symptoms... as yours . 15 secs for the plugin(s) to start.
                  I did not do a backup before upgrading the plugin. HS3 on the two Ubuntu servers is not running as a service. Rather it just starts on boot.
                  Second HS3 box is not running mcsMQTT. HS4 box has mcsMQTT plugin but it is not enabled at this time.
                  - Pete
                  Auto mator
                  HS4 Lite -
                    Here let it try starting for a few minutes and it keep trying and failing to start.
                    - Pete
                    Auto mator
                    HS4 Lite -
                      Just looking at the HS4 box and it is stull running v.5.5.1.4.
                      Copying that version over to the HS3 box.
                      The plugin v5.5.1.4 doesn't show up in the HS3 box.
                      Copied more plugin files and changed the INI file plugin version to 5.5.1.4
                      Is the plugin different for HS4 than for HS3?
                      - Pete
                      Auto mator
                      HS4 Lite -
                        Every version of the plugin is on http://mcsSprinklers.com with a filename pattern of mcsMQTT_w_x_y_z.zip. For example mcsMQTT_5_5_1_8.zip is the one that I would suggest.
                          Thank you Michael. Site is currently down via Firefox and Chrome.
                          This site can’t be reached
                          mcssprinkler.com’s server IP address could not be found.
                          - Pete
                          Auto mator
                          HS4 Lite -
                            Missing an s. It has been updated
                              I went to the INI file and disable the /homeassistant/nodes search and disabled the auto create pieces and plugin starts fine and fast now.
                              EnableAutoDeviceCreation="0"
                              SubscriptionTemplate=""
                              WildcardTemplate=""
                              Sep-16 6:45:38 PM Starting Plug-In Initializing plugin mcsMQTT ...
                              Sep-16 6:45:38 PM mcsMQTT Version 5.5.2.0 Registered with Homeseer
                              Sep-16 6:45:38 PM Starting Plug-In Plugin mcsMQTT started successfully in 66 milliseconds
                              Sep-16 6:45:38 PM Starting Plug-In mcsMQTT loaded in 500 milliseconds
                              Sep-16 6:45:38 PM Plug-In Finished initializing plug-in mcsMQTT
                              Sep-16 6:45:42 PM mcsMQTT MQTTClient is Connected to broker 1 at 192.168.244.150
                              So will leave the plugin at Version 5.5.2.0 on HS3.
                              and
                              manually add my new lightning sensor stuff...
                              Click image for larger version  Name:	lightning-mcsMQTT.jpg Views:	0 Size:	70.3 KB ID:	1419755Click image for larger version  Name:	lightningdevices.jpg Views:	0 Size:	88.9 KB ID:	1419754
                              - Pete
                              Auto mator
                              HS4 Lite -
