pool/state/chemControllers/1/chemcontroller1/pHSetpoint
{"id":1,"pHSetPoint":$$value:}
Issue with this payload is, It changes the displayed setting (7.5 to 7.2), but after two seconds reverts to the controller setting (7.5).
monitoring the settings on the webClient window never shows a change to 7.2
What I had shown above is
pool/state/chemControllers/1/chemcontroller1/orpSetpoint/setPoint
pool/state/chemControllers/1/chemcontroller1/pHSetpoint/setPoint
I understand that the HS UI for the text box was refreshing. I do not know what HS is doing in this area. Can you clarity if changing "Set Does Not Change Last Change" with checkbox "fixed/masked" the refresh problem or with the checkbox did it "create/enable" the problem?
