5.13.2 Can't write to Influx
    Following the threads in relation to mcsMQTT now been able to write to influxdb directly with a lot of interest.
    I am running HS3 with mcsMQTT 5.13.2 and influx 1.79.
    I have installed the plugin and all appears to be correct.
    I have a couple of associations made
    They appear to be storing data as the charts work ok.
    THe connection to influxd is set up and looks to be connected to the plugin ok
    The statistics tab shows that the plugin is publishing data
    Outside the plugin the database MQTT seems to be set up in Influxd
    But no data seems to be in the MQTT database.
    Any idea what wrong
    Thank you for your help
    Regards
    Liam
    I am in the middle of integrating influxDB with the charting capability. In your case you see charts because you are also logging data into SQLite. I have been working with Cor trying to get data to store into his influxDB database and he had success with one of the test builds this morning. I expect to post updates for both charting and the write capability later today so you will be able to evaluate this later build.
      Michael,
      Thank you for your quick response.
      Looking forward to testing it later.
      Regards
      Liam
        I uploaded the HS4 version with the charting and InfluxDB updates. Ran out of time to port back to HS3 plugin. Tomorrow's project.
          I have both HS4 and HS3 version references posted at Multiple lines on each of two axis & InfluxDB Charting - HomeSeer Message Board
          I have tested for 2.09 and 1.8, but not 1.7 of InfluxDB.
            Never could get influx 1.7 to work so upgraded to 1.8 and everything came alive.
