Device control button order
    Hi Guys
    Is there any explanation why I have a few devices that the HS device control buttons for mcsMQTT devices are in different orders - ie on and off swapped in HS? See attached image.
    Is there an easy way to swap them? The HS device setup looks identical.
    Many thanks for your time.
    David
    ---------------------------------------------------http://weather.penicuik.org
    The plugin lets HS decide the order. I think it is probably the order in which the buttons are listed. The specific order can be specified with the row and col text boxes on the Status Graphics tab of the device.
      Thank you Michael - that was a very quick reply and an easy fix... I had no idea that these row/column boxes were for that... and out of interest both devices had the same settings... ie 0.
      Much appreciated.
      David
