I am seeing errors relating to MSQTT in the HS4 startup popup. It seems to be working fine, I dont know when this started. I just updated to 5.16.0.5 and restarted HS4 (4.1.16.0). I still see errors
12/06/2021 11:27:26 mcsMQTT~!~Info~!~StartTrace at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) at System.IO.FileStream..ctor(String path, FileMode mode) at MCSMQTTHS4_2020.WritelogFile.StartTrace() in C:\Users\Public\Documents\TFVC\HS\MQTT\MCSMQTTHS4_2020\Write logFile.vb:line 55 Line 0 The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Data\mcsMQTT\mcsMQTT Debug.txt' because it is being used by another process.Startup Complete, 2 errors detected, check the log for more information.
