So I have tried to flash these OTA but no luck. So I took one apart to see if I can flash it directly but I don't see the connections that the instructions say I need. Can anybody tell me if this board can be flashed?
Bazz wifi 4" recessed RGBW lights - flashing
I cannot tell if the App for these is by Tuya/Smartlife. If it is then two options exist. One is using the Tuya plugin. The other is to use Tuya Convert to install Tasmota or other 3rd party firmware. Tuya Convert may or may not work depending upon when the firmware was flashed in the TYWE2S module. Tuya Convert 2.x will not work on the most recent Tuya firmware.
It appears the flashing pins were not brought out of TYWE2S onto the larger circuit card. It would likely be too difficulty to unsolder the TYWE2S to get access to GPIO 0, 1 and 3 for flashing.
