Hi Michael, will install WLED for testing purposes later this summer and wondering if MCSMQTT+WLED offer the correct support for my use case. Not installed yet so still reading/learning.
With the latest version (0.12) multi-channel is now supported (seems like Tasmota only offer one WS2812 instance per ESP). What I'd like to do is to use three different ws2812 / ws2811 (short, less than 5m) led strips and control them separately from a single Wemos D1 mini on three separate GPIOs.
It seems feasible from a hardware/WLED perspective
https://quinled.info/2021/03/21/wled...e-for-quinled/
the intent would be to create separate HS touch controls for each strip (color/brightness/effects/etc) via MQTT and virtual HS controls.
Do you foresee any issues with this setup?
I know I can use 3 controllers/ESP with stock Tasmota or WLED, but trying to optimize hardware usage.
Let me know what you think.
