I'm using MQTT plugin to operate with my Daikin system (4 splits) and work well.
I'd like to change the temperature setpoint via script.
I'm trying with:
No error in log but nothing changed.
Seems that the correct value should be in a range like -2147483648 to 2130706432.
Ok, I tried with:
16777216 is "one step" into device value set, no error in log but no value changing.
How can I set the target temperature device of my daikin split?
Cris
I'm trying with:
&hs.SetDeviceValueByRef(1373, hs.DeviceValueEx(1373) + 1,True)
Ok, I tried with:
&hs.SetDeviceValueByRef(1373, hs.DeviceValueEx(1373) +16777216,True)
Cris
