Hi there. So I finally have some time to set up mcsMQTT, so I can communicate between the HS4 install in the basement and the HTPiHubG1v2 running HS4 in the barn. The goal is to fully migrate from my HS2 server running on Windows Server 2003 so I can shut it down...
I've been reading through section 4 of the PDF, but there's so much terminology I'm not catching on to, and I've been floundering for the last couple days. I have the mcsMQTT plugin installed on both HS4 hosts, and I have the internal broker set up. The broker is running on the HS4 PC, and the HTPi is able to communicate with the broker, so that part is set.
Could I impose on someone to either point me to a sample or tutorial on how to get started with two HS4 installs running mcsMQTT, controlling each other's devices? Specifically I want to be able to have the HS4 PC (named Henry) control the Z-Wave relay switch devices connected to the HTPi, and have the devices mirrored on the HS4 PC (doesn't matter what floor/room they are, so "HTPiHubG1v2" would be fine) for scripting purposes.
Thank you,
Chris
Thank you,
Chris
