Hi Michael, just noticed the following; Let me know if you can reproduce :
When I unassociate a topic (removing the checkmark), I would expect the topic to disappear on shutdown if "Obsolete Unassociated On Shutdown" is enabled;
Ex: changing or removing sensors from a Tasmota device.
however, if the InfluxDB checkmark was enabled prior, it won't be deleted.
Actually, if you reassociate it, the InfluxDB checkmark is still enabled in the backend which probably prevents deletion.
So I guess the idea would be to automatically remove all "dependencies" when the associate checkmark is removed so it can be automatically deleted on shutdown.
Let me know if this makes sense or if there is some other reason for this behavior.
Thanks!
Thanks!
