Hi alphatech, PM sent
BlueIris and MQTT
Ok, so I finally installed the license plate Camera I bought during the Pandemic and hooked it up to Blue Iris... I am with Code Project and I am posting my MQTT messages with Blue Iris and I can see them with Mosquitto Sub just fine.. It seems to do a great job of detection.
BlueIris/LPR/Plate {"trigger":"ON", "PLATE":"872SX7", "MEMO":"DayPlate:98%" }
BlueIris/LPR/Plate {"trigger":"OFF", "PLATE":"872SX7","MEMO":"DayPlate:98%" }
I am trying to read this topic into McsMQTT and it sees the Topic, but it doesn't appear to see any payload.
Did I do something wrong here? Usually, I click on that A and I can add a device?!
HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
Plug-Ins Enabled:
Z-Wave:,RaspberryIO:,AirplaySpeak:,Ecobee:,
weatherXML:,JowiHue:,APCUPSD:,PHLocation:,Chromecast:,EasyTr igger:
You would see the plate number on that screen if you had it right. My BI5 settings look like this:
Where the full payload is: { "plate":"&PLATE", "AlertImg":"&ALERT_JPEG", "AlertImgPath":"&ALERT_PATH", "Alert_AI":"&MEMO", "Date":"%d-%m-%Y %H:%M:%S","Camera":"&CAM"}Win 11 Pro | HS4 Pro | Z wave plug in with UZB1 | BLUSBUIRT 2.0.11.0 | RFXtrx433 | Blue Iris CCTV | VU+ 4k with motorised dish | Emby | Hi-Phone HS2 | ESP32 with WLED |
Originally posted by wpiman View PostBlueIris/LPR/Plate {"trigger":"ON", "PLATE":"872SX7", "MEMO":"DayPlate:98%" }
Seems the issue is with BI sending the mqtt alert? Have you used MQTT Explorer or similar to verify what's being sent?-Wade
Originally posted by Wade View Post
I just sent this one via MQTT Explorer and it came through to mcsMQTT as the following.
I am going to copy and paste your exact MQTT message.
I am wondering if I accidently clicked a MQTT setting to disable discoveries or something-- but mine says it is clearly on...HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
Plug-Ins Enabled:
Originally posted by Traction Tim View PostYou would see the plate number on that screen if you had it right. My BI5 settings look like this:
I was able to add all of the devices normally....
Here are my settings now. I am not sure why it wasn't registering it before, especially since it worked for Wade?!?!
My screens look slightly different that others... maybe I installed the latest?
Thanks!HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
Plug-Ins Enabled:
Plug-Ins Enabled:
Excellent ! This is all undocumented, so I built that payload with the help of alphatech. It does make sense looking at the BI5 variables in the help file, but no, I didn't get to see a jpg. Some experimentaion is requiredWin 11 Pro | HS4 Pro | Z wave plug in with UZB1 | BLUSBUIRT 2.0.11.0 | RFXtrx433 | Blue Iris CCTV | VU+ 4k with motorised dish | Emby | Hi-Phone HS2 | ESP32 with WLED |
The secret sauce from BI5 are those "&" variables shown in the help file here. For example "plate":"&PLATE" will tell Homeseer what BI5 has for &PLATE, but "plate":"872SX7" will give you 872SX7 every time. Good for testing, and it does mean that you can force the output you want.
If you check DAT files for other cameras, you will also find the license-plate custom model is active on all of them. I stop this with alpr:0 on all other cameras like this:
Always learning
TimG.Win 11 Pro | HS4 Pro | Z wave plug in with UZB1 | BLUSBUIRT 2.0.11.0 | RFXtrx433 | Blue Iris CCTV | VU+ 4k with motorised dish | Emby | Hi-Phone HS2 | ESP32 with WLED |
Are you able to get this thing to trigger if you see a plate? I am getting pretty much all of dayplates. It show up in the device status, but not the value. I don't see any triggers for status-- maybe under easy trigger?
I ordered a LED light for the night time. I got it working ok but it definitely needs some more UV.HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
Plug-Ins Enabled:
Yes, it works here. I can't remember if I had to change the mcsMQTT device properties to "Text" or something, but I can see the licence plate numbers and letters text in Homeseer.Win 11 Pro | HS4 Pro | Z wave plug in with UZB1 | BLUSBUIRT 2.0.11.0 | RFXtrx433 | Blue Iris CCTV | VU+ 4k with motorised dish | Emby | Hi-Phone HS2 | ESP32 with WLED |
