The Shelly 1 is a basic module designed to fit behind non-smart switches in traditional J-Box installs and provide smarts to the previously installed switch. Unlike other relay/switch members of the Shelly family this device isolates the relay inputs and outputs from mains voltages. This means this device can be applied to any situation where smart switching using a relay is desired such as irrigation where 24VAC is switched or a garage door push button where digital 24/12/5 volts is switched.
It uses a 16A relay so it can handle typical 14 gauge household wiring without being the weak link. It comes in models with UL rating and without this rating. Obviously a price premium exists for the additional certification, but the UL rating makes it legal for install in many jurisdictions. Contrast this with many other suppliers of equivalent WiFi devices where the relay is rated at 10 amps and no UL certification exists.
The switch side of the device does only work at mains level voltages so it is not possible to safely use the input to sense digital voltage levels or contact closures.
The unit is small with dimensions of about 1.5" diameter and 0.6" depth. This size makes it attractive for install in its primary design location behind existing switches. For those who are unlucky and have shallow J-Box (no room) or have metallic J-Box (blocks WiFi from most directions) may have difficulty with using the Shelly 1 in its intended application.
The electrical connection shown below illustrates the mains connections to Load and Neutral and the switch connection also switching with mains levels. The two sides of relay I and O can be connected to anything.
Additional settings for the Shelly 1 can be found at https://shelly-api-docs.shelly.cloud/#shelly1-1pm-settings
and are shown bellow. The ones that may be of interest is how the switch input behaves, the polarity of the switch input and default state upon application of power
Assuming that the IP of the Shelly 1 is 192.168.0.123 (yours will be different) these settings can be applied using a browser with URL set with examples shown below. The red font is what will be the parts that you need to customize.
http://[COLOR=#FF0000]192.168.0.123[/COLOR]/settings/relay/0?default_state=[COLOR=#FF0000]last[/COLOR] http://[COLOR=#FF0000]192.168.0.123[/COLOR]/settings/relay/0?default_state=[COLOR=#FF0000]last[/COLOR]&btn_type=[COLOR=#FF0000]edge[/COLOR]
reset | any | Submitting a non-empty value will reset settings for the output to factory defaults |
name | string | Relay name |
default_state | string | Accepted values: off, on, last, switch |
btn_type | string | Accepted values: momentary, toggle, edge, detached, action |
btn_reverse | bool | Inverts the logical state of the input |
auto_on | number | Automatic flip back timer, seconds. Will engage after turning Shelly1 OFF |
auto_off | number | Automatic flip back timer, seconds. Will engage after turning Shelly1 ON |
btn_on_url | string | URL to access when SW input is activated |
btn_off_url | string | URL to access when SW input is deactivated |
out_on_url | string | URL to access when output is activated |
out_off_url | string | URL to access when output is deactivated |
longpush_url | string | URL to access on longpush |
shortpush_url | string | URL to access on shortpush |
schedule | bool | Enable schedule timer |
schedule_rules | array of strings | Rules for schedule activation, e.g. 0000-0123456-on |
These can also be set interactively by navigating browser to http://192.168.0.123After selecting settings option the browser image will appear as:
A common feature of the Shelly family is the Weekly Schedule options to allow the device to automatically control the output based upon day of week and time of day. This is equivalent to HS events doing the same, but does not depend upon HS. Note that HS will be informed via MQTT message of a new output state of the device so HS is able to monitor and provide notifications or remedial actions if the state update is not received when expected.
For the weekly schedule to function the Shelly 1 needs to be on the internet to use NTP time and the timezone setup. The device has an auto timezone discovery, but my experience is that it seems to always be New York (USA Eastern) rather than Los Angeles (USA Pacific) when left in the auto mode.
