Linux
    Linux
    I'm trying to use your plugin under Linux (with mono). It's failing because of use System.Data.SQLite
    Initializing plug-in(1): mcsXap Instance::Could not load file or assembly 'System.Data.SQLite, Version=1.0.87.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139' or one of its dependencies. Time to load: 188 millisecond
    I have mono-data-sqlite-5.16.0.187 installed. Would you be able to help?
    For anyone else: solution is to symlink the SQLite DLL into the root of the homeseer folder:
    ln -s /usr/local/homeseer/bin/System.Data.SQLite.dll System.Data.SQLite.dll
