xap-x10.request ??
    xap-x10.request ??
    I use mcsXap to communicate between HS3 and a stand-alone mcsSprinklers. Over the winter I moved HS to a new computer and am just starting to confirm the communication with Sprinklers. When I look at the xAP message viewer, I see lots of messages like these:
    xap-header
    v=13
    hop=1
    uid=FF.000D:0000
    class=xap-x10.request
    source=mcs.XapHS3.NUC01
    xap-x10.request
    Device=Dev_watt_curr:12
    Command=dim
    Count=322
    xap-header
    v=13
    hop=1
    uid=FF.000D:0000
    xap-x10.request
    Device=Jon00-PM-03
    Command=dim
    Count=658
    xap-header
    v=13
    hop=1
    uid=FF.000D:0000
    xap-x10.request
    Device=Dev_watt_curr:11
    Command=dim
    Count=634
    They appear to be originating in HS3. What is sending them? Is there a way to prevent them?
    HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
    It is due to the house code being between A and P. I need to make an update so that it needs to be explicitly A to P and not something starting between A and P.
      That would be helpful. Thank you.
        See if http://mcsSprinklers.com/mcsXap_3_0_0_70_HS3.zip takes care of your issue.
          Much better.
          I'm still getting messages generated for X10 RF devices, but they are infrequent enough that I can live with it. Thank you.
            Can you give me an example of the RF message?
              This is a PIR. Note: it has a standard X10 address (F7) assigned to it.
              xap-header
              v=13
              hop=1
              uid=FF.000D:0000
              xap-x10.request
              Device=F7
              Command=off
                Checkbox options provided to disable individual schema in mcsXap reporting. Updated to http://mcsSprinklers.com/mcsXap_3_0_0_71_HS3.zip
                  I'm getting a 404 error when I click on the link for v71.
                    Link fixed
                      That eliminates the extraneous messages. Thanks.
