Windows 10 and xAP hubs
    Anyone successfully installed a xAP hub on W10? I haven't been able to load the xFx-Express Hub as it wants some NET.2.0 stuff and the link supplied by the author links to later NET that when installed, still couldn't install the hub.
    Don
    I am running my original VB6 xAP Hub on W10. I also have .NET hubs that I use for Linux. It has been a long time since I remember any updates so what is at http://mcssprinklers.com/xapXap.htm should still be current. I dont recall if I ever published .NET one. It runs in console.
      I had problems with xAP on Win 10, but found that it was caused by a Windows update setting firewall rules that blocked xAP messages. Once I updated the firewall rules xAP worked again without issue. Not sure if that is a contributor to your situation, but it's worth a look.
      HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
        My issue is I can't install a xAP hub. I tried Michael's hub but it choked on a missing mswinsck.ocx file. I tried downloading just that file and registering it but had no luck. I'm not in the process of d/l Studio to see if that will install and register the correct file. So far no success and much pain.
        Thanks for the responses.
        Don
          Here is the hub I run on Linux. I confirmed it also run on W10. Look in \Config and edit to match your network.
            Thank you! That seemed to work.
            Really appreciate the help.
            Don
