i am not familiar with RS485 programming, and i have a dimmable transformer that has 3 lines in for RS485 control. i prefer to use a ZeeS2 but can use windows 10 HomeTroller if needed. i have a USB-to-RS485 adapter. can anyone advise how i can have Homeseer send the following RS485 command to the transformer, which steps down the voltage from 110 volts to 45 volts: thanks in advance, Chris
Send: 01 10 15 02 C2 01 F5 65
Modbus USB-RS485 Help
I do also get this problem on Raspberry PI. Trying to move from Windows to Raspberry and need to get this working. Any updates?
Hi!
Any update regarding the linux support? I love linux and really would like to stay with it and don't move to windows.
Guest repliedHas anyone experienced the same issue / found a solution ?
Hello.
I have the same issue with Ubuntu. Plugin worked in Windows, however in Linux i get error 'Method not found'.
Has anyone found how to solve this problem ?
Originally posted by beerygaz View PostMatt, I've not forgotten about this, I'm about to release an updated version of the plugin, I'll confirm Linux support shortly.
Hi Matt. I need to set up a Linux box and do some testing to check this.
Yup, as long as it creates a cOM port you're good. Then you just need to convert to RS485 signalling. I have seen some RS485 to USB adapters out there but can't recall where, eBay perhaps. There are some Ethernet to RS485 devices on the market too.
I lied, I'm using a USB/RS232 adapter, and then an RS232 to RS485 converter on the end of it.
http://www.usconverters.com/rs232-rs...6b590e624f7dde
