Modbus Fronius Inverter
    #16
    Originally posted by jezza View Post
    Hi, Did you ever get the plugin to read the Register? if so what setings and Registers did you read to get tit to work?
    thanks
    No sorry have pur that on ice
      #17
      Originally posted by Daarn View Post
      when I set the inverter in demomode in modbus setting then I get readings from it but when I turn off demomode then I getting errors
      That is strange behavior
      John
        #18
        Hi,
        i got a connection through the test button as well. i also got a valid Slave Response using ModScan. however I'm a little unsure on what i should set the Return Type as?
        any help would be greatly appreciated.
        thanks
ID:	1260655Click image for larger version
          #19
          Hi,
          thanks
          is it not stated in the documentation?
          John
            #20
            Hi,
            thanks
            Float32
            See file:///C:/Users/jdendunnen/Downloads/42,0410,2049.pdf (page 30).
            Otherwise try first register 40074.As 73 and 75 are all the same type (int16)
            John
              #21
              Thanks i got most of the Float32 register's working. will see if i can get any of the others working.
              thanks
