I just installed the PI and I'm not sure which way to go. I have a SolarEdge inverter that communicates via Zigbee to the SolarEdge portal. I want to capture the real time data and import what is useful to me into HS3, hopefully.
I was pointed to this information but I wonder if it's as simple as running ETH instead of using the zigbee connection, then configure so the ETH so I can read with MODBUS PI and also send data to the portal.
http://board.homeseer.com/attachment...1&d=1513506067
Where do I start? Can I use ETH or do I have to use RS485 and if so to what? Or can I just utilize the existing gateway. It is zigbee from the inverter to the gateway and then RJ45 to the router.
Thanks in advance for the hand holding.
