Finally! My inverter was replaced yesterday after power production started to fall gradually over time. It's nice that this stuff has a long warranty. So when they replaced the inverter, I had them plug into the RJ45 port. I connected to my router, enabled port 502 in the inverter and VOILA! MODBUS test sees the unit.
I'm jumping into the modbus plugin help file and I have no idea what to do next. I tried creating a device and gave it the address in the sunspec manual but I'm missing something somewhere. Has anyone connected to a Solaredge inverter? Can someone point me in the right direction please. I'm close.
FYI, my goal is to capture overall power production so I can spot when there is a problem. There are soooo many variables when it comes to power production, it's easy to just assume it was cloudier than I thought or whatever. In reality there were a couple of things that stuck out. I should have spoken up sooner and I had hoped that since all the data went through Solaredge that they would pick up on a problem. The bottom line was that after a year of wondering and not making about 2.5GW of power I finally complained. Hence the new inverter.
My goal is to capture and graph my own data and either export or use Jon00 database charting, or whatever will work.
